07-08-2019, 12:30 PM | #1 |
521
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
Car Jerked forward coming to a stop...
.Automatic... 41,000miles...rarely beat on my car... coming to a complete stop in sport mode and car jerked forward like I got tapped in the rear-end... 78degrees out and car just got warmed up... Parked it and let it sit for 30 minutes and then went back out to test... tested all modes etc after warmed up and it's fine... gotta go on a major road trip soon and really no time to take it in... anybody have this happen to them?
07-08-2019, 03:39 PM | #2 | |
Respect My Authoritah
368
Rep 873
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
07-08-2019, 05:14 PM | #3 |
521
Rep 1,288
I searched high and low for similar problem and found absolutely nothing... hoping it was just a glitch...
07-08-2019, 08:14 PM | #5 |
521
Rep 1,288
It's like the clutch grabbed for a split second launching it... weird... hopefully just a one time glitch... maybe the car was mad at me for letting my wife drive it resulting in me not beating on it and wanted it's legs stretched... well they got stretched a little... lol....
07-09-2019, 09:31 PM | #6 |
1078
Rep 2,358
I have experienced something similar. Cannot say if xHP or tune related.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
07-09-2019, 10:29 PM | #7 |
521
Rep 1,288
07-10-2019, 12:47 AM | #8 |
993
Rep 1,934
This is definitely the transmission downshifting. It gets worse in sport transmission mode and is more apparent if you break harder at the last moment. Try braking sooner and more linear or coasting to the stop earlier.
Even in Manual mode the car will shift into first when the speedo is close to 0. Have you done a transmission flush yet? This would definitely help.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
07-10-2019, 09:32 AM | #9 | |
521
Rep 1,288
Thanks for the comment! |
07-10-2019, 09:57 AM | #10 | ||
993
Rep 1,934
07-10-2019, 11:07 PM | #12 |
993
Rep 1,934
How does a flush not include a change in fluid.....
07-11-2019, 01:06 AM | #13 |
1996
Rep 2,499
They're different things. Generally, ZF recommends a change and new filter at around 60k miles but if you're an aggressive driver, 50k miles is probably better.
A flush involves using a ton of fluid and using a device to pump out old fluid and pump in new fluid (probably through the transmission cooler lines). A change is just a simple drain, drop of pan, filter replacement, and top off with new Lifeguard 8. This refreshes about half of the fluid which should be fine for such an early service. It's usually a good deal cheaper and can be done at home if you've got a way to lift all four corners of your car level. |
harkes1078.00 |
07-11-2019, 01:31 AM | #14 |
1078
Rep 2,358
Experienced it once or twice over the last 6 months or so
(A Dane in China) |
07-11-2019, 01:42 AM | #15 | |
1078
Rep 2,358
(A Dane in China) |
07-11-2019, 12:25 PM | #16 | |
993
Rep 1,934
07-12-2019, 10:30 AM | #17 | |
1996
Rep 2,499
A change simply changes out the fluid in the oil pan without trying to flush out all fluid. They are different things, but ZF simply recommends a change and a flush is probably not necessary at such low mileage. |
