Seat Belt question
08-12-2008, 10:00 AM | #1 |
Rep 35
Seat Belt question
This is not your typical, I'd like to take my life in my own hands, how do I turn off the seat belt warning indicator. I actually have a problem. Admittedly, it is probably self or passenger caused, however, I can't seem to fix it. I have an '07 e92. The passenger seat belt seems to have folded in half (length wise) and is stuck. I can't seem to get it to pull out any further (without exerting a lot of force), and I can't seem to get it to retract. Is there anything else I can do? I don't remember seeing any other posts where someone has done anything stupid like this, and I'd hate to take it to the dealer if I can fix it myself.
08-12-2008, 03:18 PM | #5 | |
110
Rep 1,252
Just click the little red '+' to the right of the smile next to the fonts section above where you type a message.
If you're not living on the edge, you're taking up too much space. |
08-12-2008, 04:14 PM | #6 |
Been There, Done That.
656
Rep 4,728
Happened to me. All I did was pull up on the buckle while straightening out the buckle as I went up. It does take some muscle.
You could take it to the dealer. |
08-13-2008, 08:30 AM | #7 |
Rep 35
Thanks, I'll try some more muscle, I was a little afraid of breaking something. If I do, then I'll take it to the dealer. I'll also take a picure and post it just to prove I'm not afraid of that either.
08-13-2008, 08:33 AM | #8 |
pull my finger to get your kinder® surprise
148
Rep 10,455
why don't you take it to the dealer BEFORE you break something?
If you're not comfortable working on your car, best to leave it to the dealership to take care of the problem under warranty.
08-13-2008, 08:36 AM | #9 |
148
Rep 10,455
btw, when you say it's folded 'length-wise', I'm guessing you meant "width-wise"??
Personally, I would remove the B-pillar cover to take a look and see if I can unfold the seat-belt.
08-13-2008, 10:08 AM | #10 |
I'm feeling much better now, Dave
Rep 305
It sounds like what happened is that your belt, during retraction, folded over so it's width doubled and then got stuck trying to go through the retraction slot in the B-pillar. Right?
This happens to me once or twice a month. (And for my e36 for years before, too). Firstly, don't worry about breaking anything by pulling strongly on the seat belt. It's designed to keep you from flying out the windshield from a crash - it can take more than you can give - guaranteed. Next, what I've found to work best is to slip a finger inside the fold, and then pull it out as much as you can get (sometimes only a 1/2 inch or so), and then force it back as much as you can while unfolding it as best you can. When it gets really stuck, it might take me 4-5 cycles to get it unfolded enough that it has the slack to pull out far enough that the fold opens up. Then it can retract normally. Good Luck!
-=] 2008 335i e92 Montego Blue & Black; Prem; Sport; AT-paddles
-=] Mods= VEI Digital Boost Gauge in RiXeffects custom Pod -=] Tinted (front: 3M Crystalline 70); (rear: Johnson InsulatIR 40 ceramic); 3M ClearBra |
08-13-2008, 12:39 PM | #12 | |
Rep 35
That's it exactly. Your description of how it is folded is spot on. Thanks. I'll give it a try. I'm not really worried about breaking anything, I just didn't want to take the b-pillar cover off. In my experience, interior trim pieces take a little more patience to deal with than I typically have. I am fairly mechanically inclined, and don't have the time or desire to go to the dealer right now. If I am unsuccessful, I'll be sure to take it back under warranty. Thanks for your help |
08-14-2008, 02:28 PM | #15 |
19
Rep 732
don't have the answer, but here is a detailed description of how the thing works (and some more). Can't remember how i found it. I looked too at disabling the chime. Should be 'easily' done by shortening the seat belt switch (but be careful the cable is next to the seat belt tightening / airbag device), but the the extender won't work anymore. On the bright side the chile switches off after two minutes or so :-)
08-14-2008, 07:39 PM | #16 |
Rep 305
Glad to help.
I hadn't heard about these boards until I started looking for details when I found I had to get a new car. Learned about an Option Credit, and just like that, saved a cool $1,210. Reading these messages are not only entertaining, and informative, but profitable!
