07-06-2019, 10:00 PM | #1 |
75
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
n55 f30 walnut blast 2019
i have 77k miles saw my valves and they were covered with carbon buildup. especially in the corners. i am most likely getting walnut blast done this friday.
curious to see others experiance with this on n55's. now that f30s have been out for 7 years. |
07-07-2019, 01:17 PM | #2 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
After 70K should be a good time to do it and should help w/ rough idle.
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
13blk335ix74.50 |
07-07-2019, 04:02 PM | #3 |
75
Rep 323
cool thanks for input.
07-07-2019, 08:03 PM | #4 |
583
Rep 1,117
Drives: 2015 BMW M235i
I thought they fixed this issue on the n55. What oil and interval do u run?
07-07-2019, 10:23 PM | #6 |
27
Rep 34
I blasted my F33 valves at 80K miles and while there was definitely some buildup, I would not describe it as “bad” and perhaps not even worth doing. But I was doing other work at the time so I had the manifold off anyway so why not?
Before image https://www.dropbox.com/s/htsfp9ep5a...%20PM.jpg?dl=0 After image https://www.dropbox.com/s/mfurdolcb4...%20PM.jpg?dl=0 |
13blk335ix74.50 Korvo368.00 |
07-07-2019, 10:26 PM | #7 |
27
Rep 34
They greatly improved the oil catching at the valve cover / PCV which greatly reduces the oil into intake (and therefore reduces carbon buildup) but all direct injection cars (lacking fuel flow to clean the valves) experience this buildup to some degree.
07-08-2019, 12:01 AM | #8 |
75
Rep 323
my valves are no where near the pictures of the n54s i have seen. but i beleive mine could use a walnut blast. figuring since i do it at 78k and its there but not horribly bad, hopefully i wont have to do it again until 160k.
i did my oil changes religiously at 10k miles for two years. this last year its been every 5k miles. good oil, always use top tier 93. i got the car with 42,000 miles so i cant speak for what went on then, which also leads me to want to do walnut blast. thanks for pictures and replies! |
07-08-2019, 06:40 AM | #9 |
172
Rep 1,375
Yeah. N55 are pretty clean in comparison to an N54. Here's a before and after from a 135i that I did a walnut blast on:
BeerHerder250.50 |
07-08-2019, 10:58 AM | #10 |
1106
Rep 1,499
I was curious about this since I'm at 77k and just got quoted $475 for the walnut blast. I'm thinking about taking that and going WMI since it will clean the valves and reduce IATs.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
07-08-2019, 11:09 AM | #11 | |
172
Rep 1,375
I still have all the stuff to walnut blast if you'd be interested. A lot cheaper than $475 -Nick |
07-08-2019, 11:13 AM | #12 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
Wow, what a difference.
07-08-2019, 02:39 PM | #13 | ||
967
Rep 2,655
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
07-09-2019, 09:42 AM | #14 |
1106
Rep 1,499
Hey thanks man. I'm really leaning towards the meth route but I'll let you know if I change my mind. I've never done a walnut blast myself. I'll need to research the steps.
07-09-2019, 10:08 AM | #15 | |
251
Rep 426
Good reference there. Seems straight forward enough if you're patient and have the tools.
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
07-09-2019, 10:43 AM | #16 |
172
Rep 1,375
Just let me know. My meth kit is arriving tomorrow and I plan on doing a walnut blast on my car prior to installing the meth kit. That video pretty much nails everything you need to know. Only thing I do differently is, I use a short wire to bump the starter to open and close the valves. Quicker and easier than hand cranking it IMO.
07-09-2019, 01:43 PM | #17 |
1996
Rep 2,499
You can buy a portable blaster from Harbor Freight for $30. If you already have a compressor and are able to remove the intake manifold, should be a fairly decent weekend job. Even a portable compressor is only about $100 and it's a good thing to have.
That said, the improvements at 77k miles for the N55 are likely not going to be as dramatic as they were for the N54 at around that mileage. I did my N54 5 series at around 75k and it made somewhat of a difference although not drastic. Before After |
BeerHerder250.50 cjlane47.50 |
