Turbo engagement at strange times
07-02-2019, 10:51 AM | #1 |
15
Rep 47
Hi all, I have this strange issue where the turbos engage upon engine startup.
When I initially start the car, the engine will rev up and down. During this time there is a loud sucking noise and the turbos will engage. After 30s to a min, everything goes back to normal. There are no driveability issues after I've let the car settle down. The chargepipe was recently replaced. I do have code 2E0F (valvetronic deactivated) which comes back every time i clear it. Do you think the valvetronic (eccentric shaft actuator) is on its way out? Could a fault boost solenoid or leak in the vacuum lines cause this? Thanks |
07-02-2019, 12:01 PM | #2 |
352
Rep 2,050
Any codes? Try swapping boost solenoids and check for vacuum leaks. First time hearing this
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
07-02-2019, 01:03 PM | #3 |
15
Rep 47
There is only one code which keeps coming back (its a BMW code)- 2E0F (Valvetronic deactivated, adjustment fault too frequent).
Otherwise I don't have any generic OBD2 (PXXX) codes. |
12-23-2020, 03:03 AM | #5 |
Rep 24
Hi, I have this same issue. Same code and noise.
I can start my car first thing in the morning, and no turbo noise, same for when I leave work to go home. However if I ever take my car out at lunch time, I can guarentee that I will have this strange noise that sounds like the turbo is spooling but wastegate fully open expelling boost. This will go on for a minute and then..... nothing. I will be heading to an indy to get my valvetronic motor recalibrated. Hopefully this will remove the code and the noises. It is strange as it only happened after a power steering pump change, but that is in a totally different part of the engine. I can only imagine the battery was pulled causing the car to need recalibration of that motor. Once done I will report back on my findings! |
12-23-2020, 04:40 AM | #7 |
Rep 24
Thanks for the reply, I have tried this already, I can hear the valvetronic motor running for 15-30 secs after ignition on but not starting the car. I then attempt to clear the code and it comes back straight away. I was informed I should calibrate using ISTA? I saw on YouTube that the ISTA runs through 450 cycles and then 50 more, as long as the motor is still OK that should remove the 2E0F code? I have not got a laptop, so will need this to be done at an Indy for now.
