06-30-2019, 04:20 AM | #1 |
Rep 27
Seat swap problem
Good day everybody! Yesterday i changed seats in my 2012 f30 from the ordinary one with sensatec(mechanics, seat heat) to leather sport lci. I also changed the blue thingy in connector because i found them a little bit different, i used my old ones from previous seats and put them to the new. What i got now - heating is working, BUT - when i turn on heat for passenger it work for driver, and the same way for drivers button Where and what i did wrong ? Thanks, Nik.
07-05-2019, 02:14 PM | #2 |
No 55mph
1622
Rep 8,476
BTW, the blue thingy in the connector is the end from the seat airbag wiring, while the white connector is from wiring to active seat belt adjuster...
I have done (2) seat swaps in my BMW's - 1 with M3 seats into my E90, the other just recently with M4 seats into my F32 I have found by experience (while some say it's not necessary) that it's best to swap over the Airbag, Active Seat Belt Adjuster, & the Seat Control Module from your old seats - to the new seats The airbag is a PITA & a little fiddly due to the wire routing, but it's worth it in the end as my swaps have had absolutely no errors & all functions work as they should > My advice would be to 1st get the Control Modules off your old seats (gray or white box that most of the wires plug in to as seen in pic below) & install them in your new seats. Make sure you plug all the wires back in to the correct spots DS for DS, PS for PS, don't mix them up, & see if that cures the problem BMW has the DS/PS wired in a funky fashion that tends to create problems when retrofitting
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
BMW DIY Guy3075.00 |
07-05-2019, 03:27 PM | #3 | |
Rep 27
This is how "control module" on my seats look like ?! [IMG][/IMG] [IMG][/IMG] About Airbag replacement - i think i can do it, not a big deal for sure, but need to unscrew seats again. =)) |
07-05-2019, 07:48 PM | #4 | |
2595
Rep 3,030
So drivers seat is good, but passenger side being a pain. I've swapped out all airbags and seat belt connectors as well...
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
07-06-2019, 11:36 AM | #5 | |
No 55mph
1622
Rep 8,476
Try swapping in your original seat modules and see if that helps
07-06-2019, 12:30 PM | #6 | |
Rep 27
Yeah, i have nothing at the dashboard about Airbags, i think they are ok. I made my seat swap with turned off the minus from the battery. Thanks! |
07-06-2019, 02:09 PM | #7 | |
No 55mph
1622
Rep 8,476
To be certain, disconnect ground from battery again when you swap the modules
07-06-2019, 02:59 PM | #8 |
Rep 27
07-08-2019, 10:43 AM | #9 |
Rep 27
Good day, update after black boxes replacement(seat modules) from old factory seats to new ones
-nothing changed, seat heat still work incorrect -good news is that there is still no errors ___________ This is how they look like, bottom is old one [IMG] [/IMG] [IMG][/IMG] ___________ And here is another question. New seats came with electro side seat support, my old ones didn't have this function. I read about it what ppl just connect 2 wires under the seat and it work... any suggestion on how is better for me to make it work ?! Under the seat look [IMG][/IMG] [IMG][/IMG] ___________ Thanks! |
07-29-2019, 04:14 PM | #11 |
72
Rep 173
Drives: BMW 340i Touring, Aston Martin
Just wondering if you swap your left and right seat modules if that fixes the problem?
07-31-2019, 02:39 PM | #12 |
Rep 27
08-06-2019, 02:35 PM | #14 |
Rep 27
08-06-2019, 11:40 PM | #15 | |
4490
Rep 10,473
I believe it could be reversed in the coding....but apparently you did it in the wiring. |
08-08-2019, 09:08 AM | #16 |
72
Rep 173
Good to hear you got it working, there are a few differences in wiring to drivers seat and passenger seat.
09-04-2020, 06:36 AM | #17 | |
@ PaddleShifterz
Rep 15
How did you mount the seat belt? Since in the M4 the seat belt is mounted to the chassis, in the F30 the belt is mounted to your seat. 🤔 |
09-05-2020, 07:44 AM | #18 | ||
2595
Rep 3,030
2016 BMW F80 ZCP
09-05-2020, 07:46 AM | #19 | ||||||
@ PaddleShifterz
Rep 15
09-05-2020, 07:31 PM | #20 | |||||||
2595
Rep 3,030
2016 BMW F80 ZCP
09-18-2020, 12:00 AM | #21 | |
Rep 4
09-18-2020, 05:38 AM | #22 |
2595
Rep 3,030
PM sent - sorry I don't have a photo and sold my car a few months ago.
As mentioned though there's a nut in the same place as your old seat. You take the nut off and slide the belt harness on the bolt and screw. Can't miss it.
2016 BMW F80 ZCP
