06-29-2019, 09:48 PM | #1 |
146
Rep 1,493
Drivetrain Malfunction
Received this message while driving. Car was shaking violently pulled over and let it sit for a minute and nothing. Drove it to the nearest auto parts store and they pulled error codes of mis firing and fuel rail/system pressure. I also noticed a strong odor from inside coming from the vents like burnt or rubber burning even from the outside. It’s a N55 btw. Where should I even start?
06-30-2019, 11:50 AM | #4 |
42
Rep 283
I had very similar, if not the same experience. It ended up being a defective fuel injector as well as a defective fuel rail pressure sensor.
2014 F32 435i /// M Sport Brakes /// Vorsteiner VFF103 /// Resonator Delete /// MP Carbon Front Spoiler /// MP Carbon Mirror Caps /// MP Carbon Rear Spoiler
@slowf32 on instagram |
06-30-2019, 12:01 PM | #5 | ||
1613
Rep 3,952
I'm going to replace the low pressure fuel pump, high pressure fuel pump, and fuel pressure sensor on the fuel rail. My theory is that if the low pressure fuel pump is failing or weak, it'll make the high pressure fuel pump work harder and fail. It was 95F out this weekend the heat didn't help. |
06-30-2019, 02:37 PM | #6 |
Resident Pedant
503
Rep 792
I myself have a verified bad fuel injector #1, and I do not have a P0087 code. So I am thinking you may have a bad #6 injector, and possibly something going on with the hpfp or fuel rail. I'm an N55 noob though.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
06-30-2019, 03:05 PM | #8 |
146
Rep 1,493
06-30-2019, 03:09 PM | #10 | |
146
Rep 1,493
All on your own? Or shop? |
06-30-2019, 03:09 PM | #11 | |
146
Rep 1,493
Lol same here. I had some kind of acknowledgment on the N54. |
06-30-2019, 03:10 PM | #12 |
42
Rep 107
Money on plug, coil or injector.
Easy low cost way to diagnose would be replace coil and plug on #4 & #6
2014 F33 435i M Sport N55 EWG - MHD - Wagner HFC - VRSF 6" Race FMIC, CP & TIC - GFB DV+ - FuelIT Stage 3 525 - EOS PI - Turner Strut Brace - Bilstein B14 - M-LSD - Turner Aluminum Subframe Mounts - PowerFlex Adjustable LCA & TS Bushings - H&R Sway Bars - Dorch Stage 1 HPFP
Phyrexia502.50 |
06-30-2019, 03:11 PM | #14 |
146
Rep 1,493
06-30-2019, 03:59 PM | #15 |
42
Rep 107
Why remove the intake??
06-30-2019, 06:41 PM | #16 |
Resident Pedant
503
Rep 792
OP are you E9x or F3x?
E9x N55 intake is all up in the way. F30 N55 intake is nicely tucked in front of the motor. You can do coils, plugs, injectors without removing the F3x n55 Airbox. The same cannot be said for E9x n55.
06-30-2019, 08:28 PM | #18 | |
146
Rep 1,493
F06 actually. Isn’t it the same as the E9x platform? |
06-30-2019, 08:29 PM | #19 |
146
Rep 1,493
07-01-2019, 08:06 AM | #20 | |
481
Rep 1,572
Loved running on the Summit Point Circuit during FATT days before we moved to FL. Ran multiple times in my 99 Mustang Cobra SVT, 99 540 Sport and the 08 E90 335i Sport. Watched one of the instructors wreck his M3 coming out of Turn 10 a little too "hot". Rolled it several times, but fortunately, walked away uninjured, although more than a little embarrassed! Last edited by Orion4; 07-01-2019 at 08:15 AM.. |
Polo088161613.00 |
