06-29-2019, 08:17 PM | #1 |
VRSF DP & CP, Straight Pipe, H&R Springs, AG Rims
Rep 22
VRSF F30 DP Fix Problem (N55)
Hey all I am back with another problem. I just had a shop install my VRSF Downpipe fix (blackbox thing) on my 2013 335i (F30). It is supposed to throw off the CEL from the oxygen sensor and get rid of it. Instead when I got the car back they claimed it did not work and called VRSF directly and could not resovle the problem. Now my car throws 2 codes instead of one I am running MHD stage 0 on it rn, would that be the cause of it throwing more codes..? I'm at a loss rn and do not know what else I can do to pass emissions.
06-29-2019, 08:39 PM | #2 |
993
Rep 1,934
1. If you have MHD, why are you attempting to use a dp fix?
2. Those dp fixes are already known to not work. 3. Read #1. MHD should be enough to suppress the CEL so you can pass emissions. This is assuming your emissions test doesn't include sniffing the exhaust gas.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
06-29-2019, 08:54 PM | #3 | |
Rep 22
06-30-2019, 06:20 AM | #4 | |
485
Rep 1,105
Also, are you PWG or EWG? Lastly, why are you running stage 0 and if you are running a catted DP, do you have the catted option checked in the MHD app prior to flashing? |
06-30-2019, 10:30 AM | #5 |
353
Rep 941
Running MHD on setting 0 is the stock setting so the cel light will show. Set it to any other map and the cell will be inhibited. MHD will not allow you to pass emissions with or without exhaust smell test. The OBDii will show o2 readiness fail.
07-01-2019, 02:24 PM | #6 | |
Rep 22
07-01-2019, 02:26 PM | #7 |
Rep 22
I dont think most NC emissions places do the sniff test so I should be fine there. Just need to remove the 2 codes I am throwing because of my O2 sensor.
07-01-2019, 03:13 PM | #8 | |
Guy with a car
98
Rep 224
15' 435i BSM on CR // BM3 Stage 2 93 OTS // NGK Plugs Gapped 0.023" // VRSF Catless DP // CTS Turbo Intake, CP, FMIC // AWE Tuning w/ Perf. Midpipe // BC Racing BR Coilovers // Apex EC-7 // Michelin PS4S // Plus a shit load of carbon
07-01-2019, 06:22 PM | #9 | |
Rep 22
07-03-2019, 02:03 PM | #10 | |
Guy with a car
98
Rep 224
TLDR: Put OEM back in for inspection then, revert after inspection as most of us with catless DPs do
07-03-2019, 03:09 PM | #11 |
41
Rep 389
I just passed NYS emissions 2 weeks ago using VRSF DP Fix. Ensure the shop installed correctly by using This DIY. Then you need to drive the car around randomly until monitors become ready. I think I logged 50-100 miles before mine became ready. Depending on what your state requirements are, you may be able to get away with 1 monitor not ready which was my case (all but o2 sensor not ready). GL
2013 EB2 335i M-Sport 6MT // BM3 Stage 2 // VRSF DP // AA CP
02-07-2022, 11:11 PM | #12 |
Rep 49
Reviving a old thread since I just installed my VSRF DP on my M235i (2016). Car got stage one tune (from a a local tuner, really good tune too) and no more check engine light but still throws the EVAP, o2S, HRT and EGR when testing for readiness, was told to drive it for a bit and then test again but it’s been a week and same issue. Not sure if this fix still works, if so where can I find it? Almost thinking I should put the stock Cat back at this point but would like to see options available before giving up.
I live in MA so should be able to pass with one one ready.
2016 M235i, 6Spd
2006 E90 330i AT Sport Package. 2003 E39 530i M Sport Package |
02-08-2022, 02:25 PM | #13 |
356
Rep 689
Drives: 22 TR X3MC
It doesnt work on EWG cars
2022 X3M Comp
2013 335i xDrive (Sold) |
