Camber plate question
06-28-2019, 05:12 PM | #1 |
Dan
Rep 90
Do I need to keep the rubber bushing if I put adjutable camber plates ..???
[FONT="Arial"][SIZE="2"]335Xi Bilstein B8 H
06-28-2019, 11:05 PM | #2 |
2896
Rep 3,726
No, the top hat usually gets replaced with the one from the camber plate kit (ground control or vorshlag) unless you are using the dinan fixed camber plates then you retain the stock top hats.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
06-29-2019, 04:57 AM | #3 | |
Dan
Rep 90
One of my rubber bushing is shot and I want to go for an upgrade. 😀😀😀 |
06-29-2019, 05:05 AM | #4 |
Dan
Rep 90
But when I look at the Ground Control ones, it seems that I can keep the EOM rubber bushing ...? Can I use them without ?? I have a Xi...
06-29-2019, 01:15 PM | #5 |
119
Rep 158
I wanted some more negative camber in the front but didn't want the cheap coilover camber plates. I decided to run new OEM top mounts and drill out the mounting holes in the strut tower. I managed to get some -1,83° camber and it has worked great for the past year.
You don't need to spend money on camber plates. |
06-29-2019, 03:46 PM | #6 |
Dan
Rep 90
I loved that !
But you kwow what, I already done that but the OPPOSITE way... My set up (Bilstein and H&R with minimal drop) is eating the INSIDE on my fronts to the cord in only one season... At minimum camber, Īm around -1... So I slotted to be on spec at -0.5... I simply cannot understand how you guys can run -2 or -3... Please help... Is all that coming from a loose shock hat... Last edited by Spitzenpradator; 06-30-2019 at 06:48 AM.. |
06-29-2019, 05:15 PM | #8 | |
119
Rep 158
Unless you run some ridiculous camber of +/-3,00° or more on the streets, then the camber won't cause noticable uneven tyre wear. BUT a toe-angle that is slightly off you can DESTROY your tyres. I highly recommend running 0,00° +/-0,10° toe in the front. |
06-29-2019, 06:10 PM | #9 |
Guest
Rep n/a
Drives:
07-01-2019, 06:20 AM | #11 |
Dan
Rep 90
Toe in or toe out ...? Cause when I think about it, with the caster angle, it seems to me that when you have a lot of toe in, you will run on the inside on the tire when going in strait line...??
07-01-2019, 06:41 AM | #12 |
1209
Rep 2,476
Toe in...
Front of car / \ | | Rear of car Toe out... Front of car \ / | | Rear of car As you can see, with toe in, the outer edge of the tire leads as the car is moving forward. This causes excessive wear to the outside edge of the tire. The opposite for toe out, now the inner edge of the tire leads, causing excessive wear there. |
07-01-2019, 10:13 AM | #13 | |
Guest
Rep n/a
Drives:
