A/C compressor pulley noisy or normal? (video)
06-28-2019, 03:57 PM | #1 |
Art Collector
2425
Rep 3,448
300k kms. Original compressor.
I’m planning to replace the bearing but am really struggling to get the pulley off. Since my car is xDrive, there is a refrigerant line smack in the middle of the compressor shaft, which makes getting a socket on there impossible. I’m sure the hub is somewhat seized to the shaft as well, but again: refrigerant line, plastic pulley, rubber dampers behind pulley... using a torch is out. Given all that, if the consensus is that my bearing is fine, I’ll just leave it be.
When I'm dead, just throw me in the trash.
06-28-2019, 06:45 PM | #2 |
12
Rep 85
In my opinion, if a bearing makes any noise when I spin it by hand, it needs, or is going to need, replacement. Our A/C unit makes a ton of noise when we operate the A/C, I am hoping to replace either the bearing or the compressor this summer. i'll be interested to see what others reply.
06-29-2019, 12:34 AM | #3 | |
Art Collector
2425
Rep 3,448
Appreciate the input! Hoping for some other responses too.
06-29-2019, 06:55 AM | #4 |
88
Rep 863
Mine was making loud banging noise and I just paid a mechanic $100 to install the $15 shorter belt to bypass the ac compressor on my e93. Instead of $1000 to replace with a new compressor. Really stupid design that the compressor pulley can’t be replaced easily
06-29-2019, 10:22 AM | #5 |
Art Collector
2425
Rep 3,448
I already have the shorter belt which I had on hand in case my compressor is out of commission when I do the repair.
I’d like to determine whether this is worth replacing though, rather than bypass it.
07-08-2019, 07:16 PM | #6 |
12
Rep 85
Any chance you have a p/n for the shorter belt?
It seems that using a shorter belt, one could remove the A.C compressor and work on it, while still being able to drive the vehicle. thanks! |
07-08-2019, 10:48 PM | #7 | |
Art Collector
2425
Rep 3,448
You definitely could, but it looks like a c*nt of a job (I have xDrive), so I don’t plan on doing it anytime soon. Let me know if you put yours on a bench though! https://www.e90post.com/forums/showthread.php?t=1416501
07-09-2019, 12:14 AM | #8 |
88
Rep 863
ACDelco 6K431 Or duralast 431K6. 435 version is too loose, I wouldn’t risk it getting suck inside the engine
