06-25-2019, 03:10 PM | #1 |
23
Rep 112
Recently my car started having this issue where it starts, runs extremely rough with low RPM surges, then dies and goes to the "off" position on the tachometer. It's happened twice now, the first time it started and died like 4 times, only staying on if I gave it some gas, and sounded like it was misfiring without any misfire codes, kinda sounded like a carbureted engine. I flashed back to stock started driving anyways car still running rough/jerky acceleration, but then it corrected itself after like 1000 feet. The second time was after coming back to the car from the store, car started, surged, then died; it started up fine after that. Both times it threw the same codes. Car was also gunshot burbling when it was flashed back to stock, but that might've been because of the burble setting from bm3 and the ecu had to relearn or something. Does anyone know what the issue might be? I'll bring it up to service advisor to look at and I'll try to get some footage.
Visiting service advisor for current problems which might be unrelated: gear shift lever illumination going out, sunroof not closing unless reinitialized, and windshield fluid pump going out. Recent changes include: bootmod3 transmission flash beta, full fluid changes (brake, coolant, diff, atf, transfer case, and oil), filled up with new gas in between the two incidents, ~500 miles ago emissions test with catsim postitapped into O2 sensor (postitaps still in place but catsim removed). I have an afe momentum with a dry filter, unplugged each coil to see if one was causing misfires, replaced sparks about 5000 miles ago one step colder, and had the lpfp recall done maybe 10-15k miles ago. Any other tests or input would be appreciated from you guys! |
07-04-2019, 01:09 PM | #2 |
23
Rep 112
So here's a video of what the problem looks like
The first 3 times it happened it threw the codes above. Then it happened when I was driving (flashed back to stock), it let out a couple of gunshot burbles, then quickly died, restarted, and went into limp mode Any ideas? Gonna be dropping off to the dealership tomorrow |
07-04-2019, 03:58 PM | #3 |
Car Hypochondriac
335
Rep 903
Drives: 2014 335i M-Sport Estoril Blue
Quick test you can do: unplug your MAF and see if the issue continues
07-04-2019, 04:31 PM | #4 |
370
Rep 552
I had almost an identical issue when I was buying Arco 91 octane. Switched to Chevron and it went away. Techron seemed to help my injectors. Had no codes and dealer couldn't replicate the issue. Yours seems to be a bit worse than mine but I wasn't tuned at that time.
Also try cleaning your MAF sensor with MAF cleaner. |
07-04-2019, 04:38 PM | #5 |
23
Rep 112
I'll unplug my MAF and clean it to see if it makes a difference. Problem is that this issue doesn't happen every startup. I had a MAF issue before, got it replaced as I was using an oiled filter, now I have a dry filter.
Think it could be injectors? I can smell gasoline and the car gunshots randomly as well. |
07-04-2019, 08:59 PM | #6 | |
370
Rep 552
07-04-2019, 09:04 PM | #7 |
Car Hypochondriac
335
Rep 903
For sure, or coilpacks too.
07-08-2019, 04:36 PM | #9 |
23
Rep 112
07-19-2019, 11:24 AM | #11 |
23
Rep 112
So took it to the dealer twice, first time they said I incorrectly installed the intake and it was leaking air, which was BS and it stalled again. Then they said my aftermarket chargepipe was loose, they test drove it twice, and now there's no codes.
I'm gonna pick it up today, but I wanted to ask if a loose chargepipe could cause my issues and throw lean/rich codes. |
07-19-2019, 11:46 AM | #12 |
5559
Rep 5,374
Absolutely. Unmetered air entering the intake can cause stumbling, stalling, lean/rich conditions, etc.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
WajahatM22.50 |
07-19-2019, 11:53 AM | #13 | |
23
Rep 112
If anything, the problem is so intermittent and elusive, I'll just wait for something to fail before taking it back in lol. |
07-19-2019, 12:55 PM | #14 |
5559
Rep 5,374
If it comes back, you might want to go to an independent BMW shop as they tend to be more willing to troubleshoot. Dealership techs are often over-worked, tend to stick to be BMW procedures, and throw their hands in the air when they see mods.
WajahatM22.50 |
07-19-2019, 01:10 PM | #15 | |
23
Rep 112
07-23-2019, 06:27 PM | #16 |
23
Rep 112
Car hasn't stalled and I feel like it even runs smoother on idle. Strange how the chargepipe became loose after 40k miles, maybe when I got the coolant changed someone bumped it
