FS: MFactory Flywheel 8-Bolt
06-18-2019, 06:25 PM | #1 |
Eating M3s for breakfast
46
Rep 299
For sale is a slightly used Mfactory SMFW 8-Bolt pattern. It was installed on the car correctly and about 1,000 miles later the rear main seal started leaking. It was removed to fix the seal and when it was put back together the mechanic did not align the dowel pin correctly on the flywheel. This caused the marks in the center shaft, which will have to be pressed out and replaced. The issue was spotted right away since the clutch would never completely disengage and I proceded to install a new flywheel. Prefer pickup in North Dallas but will ship at buyers expense. Thanks!
2009 135i ///M Sport - 6 SPD
PURE STAGE 2 . JB4 G5 ISO . MHD FLASH . 100% E85 . FUEL IT! STG 3 . FUEL IT! PORT INJECTION . BMS DCI . EVO RACEWERKS CP W/SYNAPSE DV . WAGNER EVO 2 FMIC . RB INLETS . VTT OUTLET . ULTIMATE RACING DPs . M4 PLUGS . M FACTORY FLYWHEEL . HPF 3.5" EXHAUST |
Tags |
clutch, flywheel, mfactory, n54 |
