Removal of Wheel Roundels
08-10-2008, 07:39 PM | #1 |
Rep 7
I checked the DIY for an easy way to remove Wheel roundels but couldn't find one. So I Took some pictures while I removed mine.
ToolsPIC #1) Small Jewelers screwdriver Thin Cardboard (should be thinner than a dime) Scissors Step 1. Cut a small piece of cardboard in a square. Ensure you have a good corner. Step 2. Put the cardboard in-between the Roundel and the wheel. (this will protect your wheel better than a cloth) Step 3. CAREFULLY wedge the screwdriver in-between the cardboard and the roundel. If you push it in too far you may scratch the inside of your wheel. (Circled on picture) Step 4. Gently pry the roundel away from the rim. THIS WILL DENT THE INSIDE PLASTIC OF THE ROUNDEL. Step. 5 Pull the roundel off and replace with your stock ones. Lessons learned: Remove the roundels from the wheel before you put them on. This will save you about 10 minutes per wheel, and the risk of scratching your new ones. FYI's these are 19" Breyton Race CS on 328i E92 stock height/suspension
2008 328i E92 6AT / Titanium / Gray / Gray Trim / Premium / Sports / Sports Steering Wheel with Paddle Shifters /Comfort Access / Navigation / iPod / Park Distance Control / Ordered: 02.16.08 / Delivered: Soon
08-12-2008, 01:53 AM | #3 |
Gruppe Titan
262
Rep 2,839
Drives: 08 E92 SG/Coral
Another method is to use a suction cup and pull it off with it.
Thanks for the DIY!
08-12-2008, 11:56 AM | #5 |
26
Rep 1,826
Drives: E92 335i
08-27-2008, 05:11 PM | #7 |
384
Rep 21,747
Drives: E92 335i TiAg/E46 323i TiAg
My preferred method.
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo |
09-16-2008, 05:04 PM | #8 | |
Perf BMW mag issue 147, 159
414
Rep 6,803
heres a pic of that I use-
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
01-12-2013, 09:18 AM | #9 |
Rep 15
Thanks! Bought a $3 suction cup at Harbor Freight and took 5 minutes to swap out the roundels on my winter rims for BMW roundels...
