Brake pads - which OEM brand?
06-17-2019, 05:35 PM | #1 |
Rep 15
For 13' 328i vert.
Jurid? Bowa? Bosch? Textar? Akebono? Meyle? Hawk? Genuine BMW? I don't know which pads my car had, but I bought it with 15k miles on them, now 25k and dash warning came on. I had (what feels like) zero dust on them. Never had to clean up wheels. What should I go with? Also, do I need to buy sensors with pads? Is it one per front one per rear? Thanks |
06-17-2019, 05:56 PM | #2 |
626
Rep 2,099
This is just my opinion, but:
-Genuine BMW are probably the best for actual stopping. Sure, lotta dust. -Textar are the OEM replacements. See above. -Akebono's traditionally are softer, so smoother entry to braking, but longer stop time. Less dust. -Hawk is probably a good compromise to stopping vs dust, but you are giving up a little on each end. -Rest I have no experience. As a general statement, I haven't heard consistent complaints about fitment or early failure for any brand. So it's about what your goal is vs your compromise. |
06-17-2019, 08:38 PM | #3 | |
1903
Rep 6,968
06-19-2019, 04:33 AM | #4 | |
Rep 15
The rotors could be replaced, yes, but I plan on selling this car in 2 years when my extended warranty ends, I don't want to invest into it. So basically, I just want whatever's the cheapest and makes less dust. Don't care about performance if it's like 10% difference. I don't want crap brakes, but slightly inferior is ok by me, having no dust is more important. I only wash my cars once or twice a year (summer driving only, no rain) so... |
06-19-2019, 06:55 AM | #5 | ||
1903
Rep 6,968
No dust & rotors will be on par with OEM. Zimmerman is a be OEM provider for BMW regarding rotors. Look for a kit. FCP Euro or ECS tuning both sell them. |
06-19-2019, 08:48 AM | #6 |
98
Rep 300
I got Hawk ceramic pads last time and had very minimal dust with greatly improved breaking. I'm upgrading calipers/rotors and went with textar to keep price down but they're the same as oem.
"Wheels and exhaust aren't a build"
06-19-2019, 08:50 AM | #7 |
86
Rep 1,046
Daily driving: textar (OEM), or akebono. Sporty driving or track use: hawk
2017 F80 M3 competition Sakhir Orange: // ER catless downpipes, // AA EL midpipe resonated, // MHD tune
Retired: E92 335i MSport Sapphire black: // aFe intake // Remus quad // AR Downpipe, Secondary cat delete // MHD // BMW PPK // Alpina B3 Flash // Vrsf 5" Stepped IC & CP |
06-19-2019, 12:44 PM | #8 |
1903
Rep 6,968
OEM pads will create a lot of dust. You will stop faster than Akebono pads, but not so much that it's like a HUGE factor or anything.
Lots and lots of BMW owners use Akebono pads. BOWA by the way makes the OEM brake sensor. You can get cross drilled Zimmerman sport rotors for a little more than Zimmerman OEM rotors. Either way, just make sure to burnish the pads and rotors immediately after install and don't activate the ABS system in the first 500 miles unless you absolutely have too. Burnishing - Speed up to 60mph and brake hard to 15 mph 7 to 10 times w/ out activating the ABS. Don't forget to pull the caliper pins, and apply some emery cloth to them; then put some ceramic based, brake grease on them prior to re-installing them. Last, when you change the pads and rotors, that's also a good time to change the brake fluid too, if you are close to the end of its cycle. You will need some sort of brake vac. Mity Vac works the best IMO. You can get one on Amazon. You will also need to bleed the brakes after using the vac. I'd get 4 cans or 48oz of Dot 4 synthetic brake fluid. Mityvac MV6835 Automotive Accessories https://www.amazon.com/dp/B0015POUXM..._BoNcDb8FMV0JT |
06-20-2019, 07:20 PM | #9 |
Rep 15
Thanks for suggestions. I will have it done by a shop.
So seems like general consensus is that Akebonos are likely to result in least dust? That's all I want to know. Also, one sensor for front, one for right? |
06-21-2019, 05:26 PM | #10 |
765
Rep 3,557
One sensor on front, one sensor on rear. Don't recall which side but it will be obvious. I used BOWA sensor and worked fine. Used Akebono pads and Zimmerman rotors on our 2013 X5D. I purchased parts for 2011 335D and plan to do all 4 corners but pads still good.
06-24-2019, 04:12 PM | #12 |
30
Rep 142
Drives: 2011 328i sport
I have used Akebono pads with Centric rotors to with great results on several BMWs. They don't have some of the bite like the M-sport pads on the F30, but they stop just is well if you don't mind pressing down on the brake pedal just a little bit harder. And they are easier to modulate vs. throwing out the anchor. On my previous F30, I did experienced good bite and feel with the Hawk 5.0 pads. If you are going to heat things up a bit with serious corner diving braking, you might want to check them out.
On my E90 - I am using the Akebono pads with the R1 rotors cross-drilled/dimpled that I picked up during a promotion. They were very close in price to plain disks and they do look slick! |
06-25-2019, 08:22 PM | #14 |
124
Rep 611
06-27-2019, 12:43 PM | #15 | |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
Looking up your car on rock auto (damn good pricing), it looks like there is an updated variant called the posi-quiet pro. I'd be confident trying those out as I'm a big fan of the centric brand for brakes. Nice bonus is you get all new rattle clips and caliper slider bushings with the pads. |
06-30-2019, 08:34 AM | #16 | |
124
Rep 611
I tried akebono ceramics on this car a few years ago but they made a clanking noise whenever I braked from a new direction--like they were a little loose. Tried Brembo ceramics and they did the same thing. I gave the car to my son so I switched back to OEM for increased bite, but the dust is so bad. He will be going to college soon and I was thinking I should switch back to a low dust pad before he goes because I won't be there to clean his wheels weekly. |
