06-14-2019, 07:13 PM | #1 |
Rep 10
Headlight switch question?
Hi everyone
Just got my m35i. I just find out the light switch "position 0" will turn on the low beam automatically when dark... which is same function as the "position auto" is this normal? |
06-15-2019, 07:50 PM | #4 |
66
Rep 159
06-17-2019, 03:09 PM | #5 |
298
Rep 1,079
GCP My only assumption is that since you're in canada I believe the law changed 20 years ago that there MUST be DRL on all the time no matter what, so it could be that it is coded that even on option ZERO with your headlight switch that it'll turn on. It could also mean that the low beam then turns on with the sensor when it's dark. You should be able to call the dealer to ask them. Still, I see not much point to actually have your car completely dark... if you want it that way it should be in park and off In fact, I ended up coding my back LEDs to be on with the DRL. I saw an X2 m35i for the first time on the road and didn't like the way the single light was on for the brakes.
06-18-2019, 12:29 AM | #7 |
336
Rep 1,642
Might be a Canadian thing?
Downunder when you turn the light switch to '0', only the DRLs remain on (the bright LED around the circumference of the headlights). But the low beams stay off. You can switch off the DRLs from the vehicle settings/lights/exterior menu.
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K Previous: 2009 335i LCI, Bluewater |
06-18-2019, 11:56 PM | #8 |
Rep 10
checked that already....no more drl off option in exterior light setting for x2
06-20-2019, 12:57 AM | #9 |
336
Rep 1,642
Looks like in 'Canadia' they really want you to have some light at the front
Perhaps you could code it out using Bimmercode? I used that to activate my rear DRLs so they switched on with fronts (which is all the time in my case) cheers
