06-12-2019, 08:39 PM | #1 |
1133
Rep 685
Cigarette lighter charging issues
Another funny problem with x7:
I got a escort 9500 radar detector for the x7. I couldn't turn on the device via the cigarette lighter port (in front of cup holders). The device works on my m5. My iPhone charger also did not show any signs of life when connected to any of cigarettes charging ports. I thought maybe these ports are dead, but interestingly my air pump works flawlessly with the same charging port. The pump has a longer adapter. So is it a design flaw of charging ports? Does anyone else has experience this before? |
06-12-2019, 09:28 PM | #2 | |
293
Rep 341
If my post was informative or helpful, please click the appreciate button. Thank you.
06-12-2019, 09:42 PM | #3 |
288
Rep 489
Drives: 2019 X7 50i
I can’t get it to work either. I have to use the actual USB port. Which is a lot slower.
06-12-2019, 10:24 PM | #4 |
293
Rep 341
This from the G05 forums.
https://g05.bimmerpost.com/forums/sh....php?t=1557458
06-13-2019, 05:05 AM | #5 |
1320
Rep 1,645
$0.05 cents on a low compression spring at your local hardware store is the answer. Been using a low profile USB socket charger for years this way in my X5 and 4 Series. Important because often I want the door closed and I don’t want a tall adapter that interferes or has to be removed. The spring wraps around the metal tip at the very end of the adapter and makes the necessary contact in the socket which is a few millimeters too deep in BMW’s. Mine have been used this way for 5 years in my 4 Series and 3 years in my X5 non-stop (never removed) with no issues. |
06-13-2019, 03:07 PM | #6 | |
24
Rep 161
What I did was just take a dremmel tool and ground down the diameter of the plastic end of my escort plug and it now works like a charm. It also still works fine on all other cars. See attached pic. Last edited by dmann33; 06-13-2019 at 05:25 PM.. |
06-14-2019, 11:55 AM | #7 |
3684
Rep 3,479
06-14-2019, 11:41 PM | #8 |
1320
Rep 1,645
Like the speedometer (why is it 5 mph slower?), iOS updates (why doesn’t Bluetooth work?), Polarized sunglasses (why can’t I see the HUD?), and the cigarette adapter questions that you BMW newbs are flummoxed by, the answer is that these are 5-10 year old questions and millions of others are still wondering the same thing.
Welcome to the club. LOL. I’m surprised that no one has asked why their windows have waxy streaks on them (we know the answer to that one). |
04-24-2020, 09:44 AM | #9 |
26
Rep 68
Same problem here. I soldered the tip and boom.... thanks. At first i wanted to put a nut but I might short the fuse.
Tip of advice: be careful when you solder the metal part it gets so hot that it can melt the plastic casing. I learned my lesson but it still works. You can unscrew and take the metal out to solder the part.
Everything will be alright.
04-24-2020, 11:32 AM | #10 |
Self-Deprecating Narcissist
7266
Rep 6,561
Why not tap the power and hardwire the unit?
It will be cleaner and will not have power issues.
04-24-2020, 10:49 PM | #11 |
26
Rep 68
It can be an option too, but I am not comfortable doing so in a 90K vehicle. LMAO. A few years back I tap it on my Veloster without any problem but this is a different story and this vehicle can buy me 2 Hyundai sedans. Maybe if I have a coach to help me figure it out I will try soon.
04-25-2020, 12:27 AM | #12 | |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
Not an X7, but it is an $80k+ BMW . This is my DIY dash cam install where I also hardwired it to the fuse box integrating it directly to an open/unused fuse using OEM methods (and not using the popular "add-a-fuse" method). https://f80.bimmerpost.com/forums/sh...38;postcount=1 https://f80.bimmerpost.com/forums/sh...38;postcount=1 I haven't taken a peek at the X7 yet, but I am considering putting in a dash cam. If I do, I plan to use the same method I did on my M3.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
04-25-2020, 11:50 AM | #13 | |
7266
Rep 6,561
If you're worried about warranty then ask the dealer to do it.
09-11-2020, 01:00 PM | #14 |
815
Rep 1,078
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
Glad I am not the only one, all 4 cords from my Escort & Bel radar detectors wont work, only my Radenso cord works. Will have to implement one of the solutions or get another Radenso lol
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
09-11-2020, 01:06 PM | #15 | |
55
Rep 476
I bought one of these. Worked like a charm. https://www.amazon.com/Detector-Hard...9847544&sr=8-6
2015 M6 GC CP
iconoclast7265.50 |
09-18-2020, 10:10 AM | #16 |
87
Rep 217
