DME codes 29E1 and 30FC (help)
06-11-2019, 09:17 AM | #1 |
Rep 38
Drives: 2014 Mini r60 Countryman
Hey guys
The other day i started up my 07 e93 335i to see the dreaded SES light. I pulled codes and got 29E1 (mixture control 2) and 30FC (turbocharger, chard-air pressure too low: leak-tightness). The car drives completely fine, no problems with turbos, spoil fine, boost is felt for sure. Any idea what the problem is? I think the car could use new plugs and coils (69k miles), but could be 02 sensors maybe? Just hope it's not injectors. Tempted to clear the code and see if it comes back. Could be a 1 time thing. Thanks for the input, Gavin |
06-11-2019, 10:44 AM | #2 | |
2740
Rep 4,066
If those are the ONLY codes (NO sensor codes) then my SWAG would be that Bank 2 is TOO RICH due to a leak in the intake manifold related to one of the cylinders in Bank 2 (cyl. 4 - 6), and if your Freeze Frame Data suggests the 29E1 code ONLY occurs when at boost conditions (clear code & test for SES light, read Code/ FF Data), then that increases likelihood of manifold leak on Bank 2. Also looking for smoke (dark due to over-rich) from Bank 2 tailpipe under WOT conditions (someone following) would be helpful. NOT familiar with Turbo engine, N54, JUST a SWAG, George |
06-11-2019, 11:35 AM | #3 | ||
Rep 38
