Bimmerpost
4 Series
Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Part number for wireless charger?
      06-06-2019, 12:06 PM   #1
Hysnbrg
193
Drives: 2024 X3 30;2020 M340;2016 340
Does anyone know the part number for the wireless charger tray?
This is something I didn't include in my build, and I wish I had. If there's any way to buy it, and/or retrofit the OEM one, that would be great. I'm not sure if the NFC reader in the same tray would cause any issues, but I would imagine the dealer could code for this.
      06-08-2019, 04:29 PM   #2
senderhomes
senderhomes's Avatar
40
Drives: 2020 M340I
I am trying to figure it the same thing.
      06-09-2019, 11:42 AM   #3
Encanto
Encanto's Avatar
1164
Drives: 2021 X3 M40i
Obvious question: is your car already built?
Otherwise... https://www.realoem.com/bmw/enUS/sho...52#84109437712
      06-10-2019, 07:51 AM   #4
westox
Drives: 2019 BMW 330 X Drive
Same here. My car was already built and it doesn't come with wireless charger capability. There is a pad on top of the cup holders I believe is designed for the wireless charger and it does come with the icon. Any idea how to retrofit it to make it work? Appreciate it!
      06-10-2019, 09:29 AM   #5
Hysnbrg
193
Car has been built, and is at the port in Germany.
Would be great to switch out the NFC tray with one that has both NFC and wireless charging.
Also, many thanks @Encanto
      06-10-2019, 10:03 PM   #6
BEK46
BEK46's Avatar
Drives: 2019 BMW 330 x-drive
I had the same issues and asked the service and parts managers about a retrofit. Apparently, there are other issues they are concerned with and will not do it at this time: connecting with the hot spot antenna, the led and USB port that are specific to the wireless charging mat, and then there is the enhanced blue tooth capabilities that allegedly come with it. No one seems to really know or understand the dependencies and integration and if this is simply a hardware change out (the mat) or what, if any coding changes are needed. If anyone can help on this I'll bet there would be a LOT of happy readers.
      06-27-2019, 04:41 PM   #7
juhcobywankenobi
36
Drives: 2019 BMW 330i
2019 BMW 330i  [0.00]
I'm about to buy a G20 with all the options I want except it missing wireless charging arg . So I called the dealer to find out the part numbers. So far I have these two below, it actually required the last 7 digits of a VIN number from a G20 that has wireless charging before he could give me the numbers. The parts guy also said it's not coded to the vehicle tho so that's possibly a good sign.
2019 Charging device Pad P/N 84109437712
$370.00
LTE Compensator P/N 84106803145
$344.16
LTE Compensator P/N 84108735008 supersedes above same price
$344.16
Now the question is will these just work? Doubt it probably needs coding, but where would I find that for this new of a car?
Also do we need the LTE Compensator? Not sure he said these were the two parts that came up on his search for the charge pad.
      06-27-2019, 11:54 PM   #8
ssadri
ssadri's Avatar
69
Drives: 2022 BMW 540xi M-Performance
I had the same question as well but my M340i came with the pad but without the LTE module and I can confirm that it does not charge my phone however it still for some reason triggers my phones NFC ApplePay when I place it on the pad.
2022 BMW ///540i xDrive Bernina Grey Metallic Amber Effect
2019 BMW X5 40i ///M-Sport (Recalled) Mineral White Metallic
2011 Porsche Panamera Turbo S (Sold) Basalt Black Metallic
2009 BMW X6 50i Dinan (Sold) Alpine White
2003 BMW ///M3 (Sold) Laguna Seca Blue | 1995 BMW ///M3 (Sold) Santorini Blue II
      07-01-2019, 10:48 AM   #9
nola2atx
nola2atx's Avatar
124
Drives: 2020 M340i
That's because that's where the nfc card key goes. Also, nfc activated android key.
///M340i Portimão
My Exes:
E36, E46, F30
      07-10-2019, 01:43 PM   #10
juhcobywankenobi
36
The BMW Genius told me that you cannot have wireless charging and the digital key feature in the same car. Curious if that is true or not, that would seem pretty odd if that is the case. Btw, just picked up my 330i yesterday, only thing not included was the wireless charging :|
      07-10-2019, 03:07 PM   #11
nola2atx
nola2atx's Avatar
124
Drives: 2020 M340i
Easiest solution is wireless charge pad in armrest area connected to the usb c fast charge port
///M340i Portimão
My Exes:
E36, E46, F30
      07-13-2019, 05:25 AM   #12
phillyd2
218
Drives: 2020 M340i XDrive
If by digital key you mean the NFC card then it’s not true since I have wireless charging and the card.
      07-18-2019, 02:22 PM   #13
juhcobywankenobi
36
Yes that is what she meant, and I found it hard to believe. Thanks for verifying my suspicion.
      12-27-2019, 08:17 AM   #14
BayAreaF16
Drives: F16 M Sport, F30 M Sport
Any updates guys? Has anyone installed a wireless charging mat in their armrest? Picking up my new G20 next week.
      12-27-2019, 10:04 AM   #15
BayAreaF16
Has anyone tried this one?
https://www.carqiwireless.com/produc...330i-m340i-g20
      12-27-2019, 07:14 PM   #16
juhcobywankenobi
36
I'm still a bit surprised no one has tried to retrofit the OEM solution. I could buy the parts but if it needs to be coded, and that's not even been done that sounds like a waste of money/time.
      01-05-2020, 11:22 PM   #17
gizm0duck
Drives: 2019 330i
Originally Posted by BayAreaF16 View Post
I purchased it but the instruction video that came with it is really confusing and I am not quite sure how to remove the old one. Anyone have ideas?
      01-15-2020, 10:20 PM   #18
johnmares
Drives: BMW 330i
Wireless Charging Tray Connector Photo?
I was installing a BMW OEM Wireless charging tray with NFC instead of the NFC only device that came with the car. I accidentally broke the connector and I've ordered a replacement, but I think I might have gotten the wires out of order. Does anyone have a photo of the correct orientation of the wires? I think they are Brown, Yellow, Red and Black...there are 4 Wires in a 6-position connector.
Any help would be greatly appreciated.
      01-15-2020, 10:21 PM   #19
johnmares
Drives: BMW 330i
I looked at that, but it doesn't have NFC, so if you already have an NFC tray installed, it won't work.
      01-15-2020, 10:53 PM   #20
juhcobywankenobi
36
I don't know about the wiring, but I've been thinking of trying this for sometime. How did you break the harness? I'd like to avoid doing that.
Also I'm eager to hear if it just works..
      05-14-2020, 06:37 PM   #21
fernie2002chs
Drives: G20
Did you ever complete your installion of the NFC and Wireless charger? If so was the connector the same as NFC only?
Did NFC continue to work after swap of part.
Im thinking of getting OEM NFC and Wireless Charger. My 2020 G20 only has NFC.
      05-14-2020, 07:26 PM   #22
greekcs
greekcs's Avatar
773
Drives: 2020 M340i xDrive
https://g20.bimmerpost.com/forums/sh....php?t=1706558
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
g20
