BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Tyre pressure for 20" run flat tyres
      06-04-2019, 11:35 AM   #1
Villenoir
Drives: X2
Hi all
What tyre pressures are people using, i'm hoping i am running the right amount for the load i am carrying:
Two adults and two teenage boys.
Does 40psi seem a bit high to you?
Thanks!
      06-04-2019, 12:30 PM   #2
rounderman
148
Drives: 2019 X2 M35
2019 BMW X2 M35  [9.50]
do UK cars have a sticker in the driver's door jam? in the US that sticker has the proper tire pressures otherwise I would look in the owner's manual
      06-05-2019, 08:39 PM   #3
Patrick852
Hong Kong
66
Drives: 15 320iED, 18 X2 sDrive20i MSX
My sticker says 32psi, but dealer put 40psi, it jumps like hell over rough surface, I lowered it to 32 and is now much more acceptable.
      06-05-2019, 09:12 PM   #4
bimmerdriver2
bimmerdriver2's Avatar
180
Drives: 2020 M2C DCT
I recall reading somewhere that the pressure is supposed to be 40 psi. I checked on the door pillar and it says 39. In general, you should not go lower than the pressure on the door pillar.
      06-06-2019, 11:31 AM   #5
Villenoir
Drives: X2
40psi all round, just seems like a bit of a high figure. When i got the car each tyre had a different tyre pressure reading ranging from 32 to 37.
If you have a lower than recommend tyre pressure you'll increase drag and you'll suffer from a higher than normal fuel consumption.
Thanks
      06-10-2019, 10:11 PM   #6
strripedz
Drives: X2 F39
My sticker says its 2.4bar (34.8 psi) on the front and 2.6bar (37.7 psi) on the back if the car is only carrying 1 passenger and 1 driver.
However, i set mine to 34 all around and it feels perfectly fine.
xbimmers
