05-31-2019, 07:13 PM | #1 |
34
Rep 154
Car is pulling to the right after new tires installed
I have a 2014 335i sport line with adaptive M suspension (square setup). Purchased some Pilot Sport 4S tires at America's Tires about 3 weeks ago and had them installed. The car has been pulling to the right ever since.
Thought I might need an alignment so I had that done at a different place last week and that hasn't helped. When I picked up the car originally, the guy at America's Tires did mention that they had a hard time with some of the lugs because of rust. I hope they didn't mess something up trying to get the wheels off. I'm taking it back tomorrow so they can inspect the wheels, tires... etc. The car pulls the most when in sport mode and the least in eco. Don't know if that means anything. Any ideas on what could be causing this? Anything I should ask the tire guys tomorrow? Thanks! |
05-31-2019, 08:26 PM | #2 |
18707
Rep 14,115
Drives: G82 M4C X-Drive
They had a hard time with the lugs because of the rust? Does that mean they couldn't get them out because they were stuck?
What was their solution then? Often, hitting a rusty lug will help loosen it, but if they aren't careful they could have cracked the lug or worse your wheel. Have them remove the lugs, inspect for cracks, and also GET NEW LUGS. You don't want to end up with a damaged wheel the next time they get stuck. You also don't want to drive around with a broken lug, which could lead to the wheel not seating evenly and premature tire wear or worse a blow out or major damage to your wheel and suspension components.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-31-2019, 09:43 PM | #3 |
34
Rep 154
Thanks for your reply! The guys who did the alignment also swapped both front wheels. Wouldn’t that rule out the front wheels or tires? Maybe the pull is caused by one the rear wheels being cracked? I’ll do just as you suggested, carefully inspect all wheels for cracks.
They swapped out the old lugs with some new ones. Not sure how they removed the old ones. |
06-01-2019, 07:17 AM | #4 |
88
Rep 125
Drives: 2024 BMW 228i Gran Coupe
If you have found nothing else so far..........one thought (a bit obtuse perhaps) is that one of the tires is mounted incorrectly as a Uni directional (backwards-rotation opposite of what it should be). I had this done years ago on a car and it was amazing what that mistake can do.....just a thought (as obtuse as it might be).
Machinebuilder278.50 |
06-01-2019, 07:46 AM | #5 | |
6659
Rep 15,858
If an alignment made no difference after the new tires were fitted, it does suggest it is the tires. If all was fine before new tires, it is possible that the car had bedded to the original tires as they wore, running true, new tires are showing up a problem with the whole 4-wheel geometry. Cracked wheels shouldn't influence geometry, vibrations yes, but not influence geo' calibrations. |
06-01-2019, 07:49 AM | #6 | |
6659
Rep 15,858
Even asymmetric designs (like the Michelins) if not mounted correctly (Outside, out) could cause a pull. |
06-01-2019, 09:39 AM | #7 |
102
Rep 189
Only thing I can think of is alignment or tire mounting (if the tires are unidirectional all seasons, maybe a wrong facing tread may cause issues, but I'd imagine more so in the rain/snow). When you did the alignment did you do front and rear?
06-01-2019, 09:58 AM | #8 |
5886
Rep 10,256
I suggest to start at milestone zero: remove and inspect all wheels, lug nuts, inspect for cracks and damaged lug nuts, and RoadForce balance all wheels prior to mounting.
It's best to repeat the installation process and ensure there are no surprises (for safety reasons as well). Keep us updated! |
06-01-2019, 11:04 AM | #9 |
2589
Rep 2,432
Drives: 2021 M2C
My suggestion would have been that the minute you noticed it was pulling, to take it right back to the shop. I still think that is your best bet.
06-04-2019, 06:08 PM | #10 |
34
Rep 154
Appreciate all the responses. Took it back to America’s Tires for an inspection. They told me it would take over an hour to complete but got a text msg less than 20 minutes later telling me they were done... hmmm. I did ask them to swap the wheels as well ( back to front, front to back).
The guy proceeds to tell me they didn’t find anything unusual and suggests that I take my car to this other place that does alignments. But guess what, the pull is gone! Ok maybe it’s still there just a little. Minor enough that it could have been there already and didn’t notice on the old tires. So I don’t know if 1) they found something obvious and resolve it without telling me; 2) the wheel swap fixed the issue because I have an issue with one of my wheels; 3) something else? Either way, quite happy to be driving somewhat straight again |
06-04-2019, 07:04 PM | #11 |
1996
Rep 2,499
How strong is the pull and what direction is it? If it's a light pull to the right, it might just be normal road conditions as a lot of roads tend to pull a straight car to the right. We tend to notice small issues with our car after we get it back from the mechanic although they were there the whole time.
Also, your old tires might have worn in a way that compensated for an issue in your suspension. But if your alignment was done properly, I don't see that as being an issue. Also, you should have received alignment values from the alignment shop. Since our cars can only adjust toe in the front, it's possible that something is out of alignment on your front wheels that the alignment shop can't fix. It's worth looking at the printout to see what that might be. |
06-04-2019, 09:07 PM | #12 | |
5886
Rep 10,256
06-12-2019, 04:13 PM | #14 |
79
Rep 156
I put on 4S's on my 335i x w/ adaptive suspension, and my car began to pull to the right as well. More evident under heavier acceleration. Wasn't too bad, but it's at the dealership now, getting a 4 wheel alignment done while it's there for maintenance.
Will report how it drives after the alignment. I do run the recommended 32/38 set up. |
06-12-2019, 04:21 PM | #15 | |
34
Rep 154
Interesting. I hope it’s not the suspension.
Already had an alignment done although it wasn’t at the dealership. Dealership charges $300 for an alignment in the Bay Area 🤯 Did you notice the pulling right after you installed the 4S’s? Please let me know if the alignment resolves the issue. Quote:
06-12-2019, 04:59 PM | #16 |
79
Rep 156
No, not right away. It is more pronounced now, after a couple of thousand miles. Roads are shitty here, so I hope alignment is all I need. They're charging $200 because they're including "a pothole special"... I think they had a $150 option, but whatever.
I pick up the car tomorrow. |
06-17-2019, 10:53 AM | #17 | |
34
Rep 154
06-17-2019, 12:50 PM | #18 |
79
Rep 156
Oh, sorry, Posull78, the dealership ended up keeping my car because they decided to replace the door lock actuator.
I'm still driving the loaner. I'll be sure to let you know when I get it back. |
06-20-2019, 08:50 AM | #19 |
79
Rep 156
Picked up my car today. Just drove to work in the rain, top speed 55ish. No noticeable pulling, even under heavier acceleration. I'll update if the pull comes back.
06-20-2019, 09:06 AM | #20 |
343
Rep 2,118
06-20-2019, 01:35 PM | #22 |
79
Rep 156
