05-30-2019, 02:07 PM | #1 |
88
Rep 409
Going in for last warranty service before expiration - Advice please
I am bringing in my 2015 335i xdrive for its last service before my 50,000 warranty ends. I would like to get the most out of it. What should I tell them to check and try and get replaced?
Thank you!
2015 335i X-drive, Black Sapphire Metallic, M Sport package LOADED. MPE/VRSF Charge Pipe/BM3 Stage 1 93 Octane
05-30-2019, 02:18 PM | #3 |
2966
Rep 6,003
Brake Pads, rotors, wiper blades, key fob batteries for both remotes, and cabin and intake air filters. Also brake fluid, replace spark plugs, new 12v battery.
05-30-2019, 02:36 PM | #4 |
21
Rep 81
Simply put, they don’t want to take the time to look.
I took mine to a trustworthy independent shop first. They found the battery was low ... despite the dealer having serviced the car just a few weeks earlier. I took the car back to the dealer, told ‘em that I’d seen a battery alert ... they replaced the battery under warranty. |
05-30-2019, 02:44 PM | #5 | |
133
Rep 433
With that in mind, what should a shop look for on a 2015 328i with 28,500 miles on it? |
05-30-2019, 02:50 PM | #6 | |
2966
Rep 6,003
05-30-2019, 02:56 PM | #8 |
2966
Rep 6,003
The dealer told me if the battery goes bad due to being insufficiently charged because it was sitting they won't cover it as they expect you to use a battery maintainer so make sure to tell them that if they try to deny coverage.
05-30-2019, 03:42 PM | #10 |
1999
Rep 2,499
You might have a good dealership where they will catch everything wrong with your car and fix it for you under warranty. But you probably have a dealer that will only find stuff wrong with your car after you warranty is up since the profit on that work is higher.
It might make sense to take your car to a 3rd party independent mechanic and let them know what you're there for. Basically do the equivalent of a pre-purchase inspection on a used car. I've personally never done that, so I can't guarantee that will work out. Something you should definitely have checked is the transfer case. That's a common issue in xDrive cars and pretty expensive to fix after warranty is up. Also just check for any leaks at all. Especially around the engine, the oil filter housing, oil pan, transmission, transfer case, and the differential. Those are all things you'll want to do under warranty and things that the dealership can't deny need work. |
05-30-2019, 03:52 PM | #11 |
731
Rep 1,045
You know they're going to say everything is fine without looking right ?
Mods: Dinan Tuned, Intake, Catless DP
05-30-2019, 04:12 PM | #12 | |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
However, as mentioned by other members, the OP can take the car to a indy for added peace of mind and they can tell him if there are any discrepancies present. |
05-30-2019, 04:21 PM | #13 |
2589
Rep 2,432
Drives: 2021 M2C
05-30-2019, 05:51 PM | #14 |
221
Rep 529
Have them look under the car where the transmission output shaft mates with the transfer case input.
My 2015 F32 x-drive had a leak there that I wished I would have checked for on my last warrantee visit. podman |
05-30-2019, 05:56 PM | #15 |
731
Rep 1,045
I don't but I do have common sense, and I do have experience in dealing with 3 different BMW dealers locally where I am to come up with that conclusion.
05-30-2019, 06:13 PM | #16 | |
6799
Rep 3,677
However, I do have two local Indy shops that are top notch in my area and it helps that both are under 10 miles from my house: Active Autowerkes & Miami Performance Inc (MPI) If the OP takes his car to his local dealer and they claim to find nothing, yet he goes directly to an Indy and they find stuff, then that just adds fuel to the fire that all dealers are this way. From my experiences, I have been fortunate. |
05-30-2019, 06:17 PM | #17 |
247
Rep 776
I recently had a tech recommend new tires, but no mention of the seeping diff that you could see in the service video.
Last year I had another that recommended an idler bolt (had already been changed) but no mention of an obvious seeping turbo oil feed line. Definitely pay knowledgeable Indy shop to perform a semi-invasive inspection. Removing covers etc. |
05-30-2019, 06:20 PM | #18 |
21
Rep 46
I can't emphasize any gasket enough. I had to have 3 of them done right before my CPO was up. I had an incompetent dealer not catch 4 major things that were easy to catch. I took to an independent, documented everything for a small fee. I then went to a different dealer and had close to $7,000 of retail repairs covered.
upsidedownfunnel1999.00 |
05-30-2019, 06:22 PM | #19 | |
221
Rep 529
Indy shops aren't a panacea either. podman |
