05-30-2019, 12:20 AM | #1 |
Rep 6
N55 trouble...
Ok so let me explain this. I went stage 1 bm3 back a month ago. It was night and day. My car turned into a monster (for what I'm used to) and I loved it.... while it only lasted for a few hours. Within that time, my Charge pipe failed. I then was forced to drive home very slowly. While driving i did notice that the cars idle was terrible (shut off on me once) and some other things. However, this is no surprise considering what had just happened. When I got back I noticed that the sensor that attaches to the cp was dangling still fastened to a piece of the original cp. I undid it and stored it my car. A week later I finally got a new cp and installed is (evolution raceworks I think). While it was fixed and everything I did notice the rough idle persisted (really just during the cold start). It would become violent and shaky for a few seconds and then settle. It has been roughly a month and the problem has persisted. This is the biggest note. Since the cp swap and the rough idling, the power has dramatically reduced alongside the responsiveness. I purchased the car two years ago as a 2013 335i CPO with 30k miles.... now it has 66k. I have no idea if the prior owner or dealership has changed the spark plugs (more of when they did). Can anyone help. I've read and I'm guessing it can be spark plugs or coils or injectors. Also a note is after about 5-10 seconds, the rough idle stops. The reason I'm irritated is mostly the power drop and lack of responsivness. Any ideas?
05-30-2019, 08:15 AM | #4 |
Respect My Authoritah
368
Rep 873
Shit man I have the exact same idle issue after a downpipe install. Subbed!
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
05-30-2019, 09:12 PM | #5 | |
197
Rep 417
You may also want to try reinstalling the cp while making sure the o-rings sit properly, especially the one side that connects to the FMIC. Also make sure the silicon house and pipes are sitting flat, not slanted. |
05-30-2019, 10:00 PM | #6 | ||
Rep 6
05-30-2019, 10:37 PM | #7 |
120
Rep 233
05-30-2019, 11:11 PM | #8 |
1999
Rep 2,499
When you installed the charge pipe, did you install the o-rings for both the upper and lower openings? Have you also tried flashing back to stock to see if it improves?
floridaorange10168.00 |
05-31-2019, 08:05 AM | #10 |
43
Rep 165
I had 64k miles when I installed my stage 1 tune. 2 of my coil packs failed in the first 500 miles of having my tune installed. I didn't know they were failing at first...I did notice rough idoling and worse gas mileage. I didn't know they failed until I started getting misfires. They were the original coils that came with the car. I think the added stress on the engine from the tune amplifies any engine problems that were already there but just unnoticeable. If you're changing your spark plugs spend the extra money and change the coil packs also. BMW uses eldor coil packs now you can find the non BMW branded OEM coil packs online for $28-$35 a piece. I personally don't like the Delphi OEM ones I had. I don't think coil packs should fail that soon. Tune or no tune. I've had cars with 140k miles on the original coil packs. It's definitely worth the change at that mileage. Since I've changed mine I have no problem at all! Car runs super smooth with no hiccups!
05-31-2019, 12:16 PM | #11 |
5886
Rep 10,256
Did you have a chance to scan for stored codes? It's typically the first step.
PS. Posting in the dedicated N55 forum will yield more responses. |
05-31-2019, 12:42 PM | #12 |
731
Rep 1,045
wow, this is why I'm hesitant to get a tune. Hearing stories like this, something else must have blown with the charge pipe. Luckily my DIY catless downpipe caused no issues, not even CEL. But hopefully everything turns out ok for you.
Mods: Dinan Tuned, Intake, Catless DP
city1991231.00 |
05-31-2019, 01:35 PM | #13 | |
197
Rep 417
It just sucks that BMW uses a relatively weak chargepipe on these cars. Just like any other manufacturer, there is always gonna be at least 1 flaw in the consumer's perspective. BTW, didn't you get a CEL at one point? I remember reading your post the other day, maybe it hasn't come back yet |
05-31-2019, 01:42 PM | #14 |
BMW CCA 69606
86
Rep 227
05-31-2019, 05:35 PM | #16 | |
Masterchief
364
Rep 1,018
he also could have possilbly messed up the TMAP sensor on the cp alot of people experience rough idle due to a new intake as well. check your MAF sensor as well.
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
05-31-2019, 05:38 PM | #17 | |
Masterchief
364
Rep 1,018
it is very well known in this forum that CP blows up under stock. first thing he should have done was get a new CP and sparkplugs before tuning. btw your dp will throw a code eventually. they all do
05-31-2019, 05:42 PM | #18 | |
10168
Rep 2,671
05-31-2019, 06:02 PM | #19 | ||
731
Rep 1,045
05-31-2019, 10:39 PM | #20 |
202
Rep 533
I recently installed a bead charge pipe. It was not easy like posts have said. Anyway it seemed to be installed correctly. Went for a drive and went into limo mode. I had a leak. After taking the car apart I notice the charge pipe mid coupler was barely on the pipe causing a leak. Fixed it and all is good.
05-31-2019, 11:03 PM | #21 |
82
Rep 170
seems no one has mentioned this.
When your charge pipe blew, it probably obliterated your o-ring up top with it. Did you get a new o-ring and install it on both the top and bottom of your new charge pipe?
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i |
05-31-2019, 11:30 PM | #22 |
46
Rep 194
I don't know, 30,000+ miles
