BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Next step after M3 Subframe Bushings
      05-29-2019, 11:20 AM   #1
minaret
57
Drives: 2008 E91 ZSP
I went with M3 subframe bushings 4 years ago. Rear suspension felt planted and there was minor NVH from the Quaife LSD. Now after 84,000 miles and 33 track days the car feels cushy. I use NT01s for track days. Summer climate here is hot and dry. Are Delrin subframe bushings still a popular upgrade from M3 bushings?
2008 E91, ARC-8, 255/40/17 NT01, ER sport cooler, TCK camber plates, coil-overs 400# front 700# rear, Koni SA shocks. M3 Subframe bushings, front + rear control arms, tension struts, strut brace. Quaife, Carbotech, Schroth.
      05-29-2019, 03:20 PM   #2
Torgus
Slow.
Torgus's Avatar
3782
Drives: Single Turbo N54 on Meth!
2007 BMW E92  [10.00]
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
I would go solid aluminum, do the subframe bushings in aluminum while you are in there. The bushings are not that expensive at all. Tuner makes a full set.
      05-31-2019, 03:34 PM   #3
Tambohamilton
3058
Drives: E91 330d
They seem to be, yes. A large factor is that they're way easier to press in than aluminium bushings, and in terms of handling/performance they're indistinguishable. NVH will basically be identical to aluminium ones too.
Whatever you go for, maybe you've got a vernier caliper and you could measure the diameter of the bushings before you press them in? That way I could make my own without having to take my car apart first!
      06-01-2019, 07:57 AM   #4
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
What are you using for Differential bushings?
      06-01-2019, 09:32 AM   #5
feuer
feuer's Avatar
4276
Drives: wife crazy!
Those miles and track day took toll more on other suspension components rather than the subframe bushings. I assume it would still feel cushy even if you weld the subframe onto the chassis.
      08-30-2019, 04:21 AM   #6
streetpro
streetpro's Avatar
Czech_Republic
87
Drives: e92 335iA
Try a diff lock-down kit, it worked a lot for me to get a rid off of any rear steer .-)
"If everything seems under control, you're not going fast enough.” Mario Andretti
