05-29-2019, 10:40 AM | #1 |
Rep 37
Adhesive-backed aesthetic add-ons?
Hello all, first post on the forum. Great resource for me as a new owner of a 2018 330i. Thanks in advance for your contribution(s).
I'm curious what you all think about 3M / adhesive-backed aesthetic parts (spoilers, M-Performance side skirt decal, etc). Do you have any concerns using adhesives to attach things to your car? Should you decide to remove it, have there been any issues with adhesive residue, paint fading/discoloration, or marring from the removal process? I'm looking to purchase and install a small / low profile carbon trunk spoiler, but have reservations about essentially taping it to my trunk. Thanks! |
05-29-2019, 10:52 AM | #2 |
Respect My Authoritah
368
Rep 873
The adhesive that you're referring to is designed to be applied to paint. It won't come off until you want it to come off. As in, I wouldn't put the spoiler on if you don't want it to be there for the life of the car. If you do remove it someday, you might see discoloration from UV light not touching the underside of the spoiler. The tape can be removed.
Auto manufacturers have been using tape instead of mechanical fasteners for years and this will not change. There's plenty of this tape on/in the car that you probably didn't know about. It's not just aftermarket parts that have it. If you're worried about it being removed in a car wash, or with a pressure washer, don't be. It's robust and weather resistant, to some degree. Obviously, residue could be there after removal. It really depends on the quality of adhesive that the part manufacturer used. There are lots of 3M counterfeits, not to say that 3M makes the only good adhesive. Clean the area well, for best results.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
05-29-2019, 12:53 PM | #3 |
1471
Rep 975
Don't worry, the 3M tape is perfect for that. The key is prepping the surface for adhesion.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
05-29-2019, 01:42 PM | #4 |
731
Rep 1,045
Its perfectly fine, wash and clay bar the area before you put it on and if you worry about the spoiler adhesive residue, just use the clay bar to clean it and it'll be as good as new. I have the 3M adhesive on my interior carbon fiber trims (see pic below). They are removable and any residue will come off easy with a trim cleaner.
Mods: Dinan Tuned, Intake, Catless DP
05-29-2019, 02:15 PM | #5 |
88
Rep 125
Drives: 2024 BMW 228i Gran Coupe
I used this approach on several cars in the past (usually lip spoilers on the trunk). I just did this a week ago on my 2018 330i when I installed the M wing.
05-30-2019, 01:15 PM | #6 |
4654
Rep 6,033
Respectfully disagree with just about every prior post. I would not rely on tape adhesives for exterior body parts. BMW makes this product for a very sound reason.
https://www.ecstuning.com/b-genuine-...82699408866kt/ Tape adhesives can work well if the conditions are proper. In my past managing a vehicle program at another car company, I can remember a yard full of vehicles being held as a slight change in the adhesive by the supplier of bodyside moldings without our plant knowing and adjusting the install process accordingly resulted in them peeling off as they sat in the yard. For adhesives to work properly, these factors need to be considered. Surface temperature Surface prep/cleanliness and what solvent used Part temperature Pressure duration when applying Pressure intensity across adhesive surface I'm not suggesting it can never work. The point is that the variables are often not within the specified range for the adhesive and you might mistakenly think the spoiler is well attached. The problem is when the guy behind you at highway speeds is the one who finds out your spoiler, at the height of his head, is not securely attached. I'd use the Betalink for anything on the exterior.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner Last edited by Sportstick; 05-30-2019 at 01:22 PM.. |
05-30-2019, 04:49 PM | #7 |
368
Rep 873
I don't remember adhesive being that hard to use.
05-30-2019, 05:07 PM | #8 |
4654
Rep 6,033
I didn't say it was hard. I pointed out that it has several fragilities and more failure modes, some of which may not be apparent at first.
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
05-30-2019, 05:09 PM | #9 | |
368
Rep 873
https://www.m3post.com/forums/showthread.php?t=651870
05-30-2019, 05:12 PM | #10 | |
4654
Rep 6,033
Betalink is far more robust, and is the product BMW recommends for such aftermarket purposes.
05-30-2019, 05:29 PM | #11 | ||
368
Rep 873
Pressure is very important with adhesive, but how much do you really need? Adhesive needs time to wet out, and an initial pressure helps this process. Cleaning is the step most people skip and it's the most important. Never use something like wax right before. You need to clean with isopropyl, not speed shine or detailing cleaner. My dad and I have been using tape to apply spoilers to both paint and glass for years. Never experienced a failure. If you can use adhesive properly, which isn't that hard to do, it offers you more flexibility if something happens to the wing or trunk lid down the road. We've even removed them, years later, with no issues and an intact spoiler which could be sold. From the sounds of it, glue results in a broken spoiler and a paint nightmare, if you decide to remove it.
BeerHerder250.50 |
05-30-2019, 05:31 PM | #12 |
731
Rep 1,045
Arn't all these user error you just mentioned ? Anything will not work with user error though lol. I'm not disagreeing with you, you are probably a professional who knows what you're talking about.
05-30-2019, 06:04 PM | #13 |
4654
Rep 6,033
Again, I am not saying adhesive tape products don't work. Clearly, from my earlier post, we relied upon such in OEM production in our plants with good success for more than hundreds of thousands of vehicles. However, the conditions were tightly controlled and when a variation occurred, a failure followed. In the wider variations of conditions in DIY installations, the chances for failure are greater. I can't recite the specs for each adhesive tape product, but as a category, they are less robust than something such as Betalink. We can each manage risk as we best see fit, but Betalink is demonstrably the more secure methodology.
05-30-2019, 06:12 PM | #14 |
368
Rep 873
I agree with your last sentence. I'm not saying that tape is stronger than glue and I never did. I had two main points:
Tape offers the user flexibility if they need to remove it years down the road. Tape isn't as hard to use/apply as you're misleading people to believe.
05-30-2019, 06:18 PM | #15 | |
4654
Rep 6,033
05-30-2019, 06:38 PM | #16 | ||
368
Rep 873
Now you didn't make that argument?
05-30-2019, 06:50 PM | #17 |
1999
Rep 2,499
Without getting too technical, those adhesives can fail in extremely cold or extremely hot temperatures. But probably not for as long as you'll own it.
05-30-2019, 06:51 PM | #18 | |
4654
Rep 6,033
I did not need to reach far to understand the variables. These were explained by adhesive experts to us when we had the large volume failure at a plant and I shared what I recalled. I have made no comments about the ease of installation. I pointed out more than once what variables are at play, perhaps unknown to the naive installer who simply and happily goes about a seemingly easy DIY project in their driveway. But, for those who apply the part as best they can, I have not identified any difficulties which make it burdensome, just risk factors. It is at some later time that one of those variables may make themselves apparent as a root cause of a subsequent failure, and the failure can be catastrophic, particularly to the following vehicle. Failure may very much mean it was not applied well. But, that has no correlation to the degree of difficulty the original installer experienced. I presume most just clean the surface and apply the part without knowing much more about what the actual factors are.
05-31-2019, 09:26 AM | #20 |
Monobloc
332
Rep 447
Drives: '02 M Coupe - '19 F31 330ix
Can't we all just get along?! Chet mayn!
-2023 Honda Odyssey Elite - Sonic Gray Pearl / Black
-2019 F31 330ix Individual - Champagne Quartz / Coral Red (M-sport, Exec, Premium, Track) -2004 Honda CRV AWD - Silver / Black -2002 S54 M Coupé - Steel Gray / Dark Gray/Black |
05-31-2019, 09:56 AM | #21 |
Rep 37
I guess I should have also added that I'm in Calgary, Canada where we have some pretty broad temperature ranges. Winter temperatures can hit -40 F/C and summers can reach +35C / 95F.
Obviously I wouldn't install any adhesives in -40...but even with the ideal install temperature being observed, I feel the +- 75 degree swings would lead to premature failure. |
05-31-2019, 11:17 AM | #22 | |
11
Rep 20
