05-28-2019, 05:10 PM | #1 |
137
Rep 139
Anyone know what these 3 DME codes are?
I pulled the following 3 soft codes from BM3 diagnostics:
235410 ... no description available 21A110 ... no description available 138102 ... exhaust flap control; short circuit from ground (did check my exhaust flap connector and all is connected)
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 2 | ER FMIC | FabSpeed Catted DP | ER CP |
2016 F150 2021 RnineT 2022 K1600B |
05-28-2019, 05:43 PM | #2 | |
1410
Rep 1,803
21A110 - Engine torque limitation due to emergency operation request from EME emergency operation manager controller 138102 - exhaust flap activation: short circuit to ground
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
dougt.ah3137.00 |
05-31-2019, 12:02 AM | #3 |
137
Rep 139
Found the cause of the 138102 exhaust flap short. It appears debris slit one of the wires at the connector to the actuator. Was able to remove (de-pin) the terminal from the connector. My local BMW dealer had a terminal in stock which I was able to make work. Soldered in a new wire and was goo0d to go.
If anyone needs the terminal part number it is 12 52 7 545 852. Had to modify it slightly.
01-29-2021, 04:12 AM | #4 |
Rep 4
Hi sorry to reopen,
I am getting code 138102 - exhaust flap activation: short circuit to ground can i ask what is the problem is the actual exhaust flap or something else? How urgent do I need to sort such a thing out? |
01-29-2021, 09:44 AM | #6 |
981
Rep 1,560
Also if you have "short circuit to ground" it could be draining your battery.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
