F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > N55 guys, have you replaced your OFHG? If so, did your engine seize up afterwards?
proTUNING Freaks
View Poll Results: Has your OFHG been changed? If so, take the poll.
My OFHG was changed and my engine ran fine immediately afterwards. 26 83.87%
My OFHG was changed and my engine seized up immediately afterwards. 5 16.13%
Voters: 31. You may not vote on this poll
      05-28-2019, 12:26 PM   #1
Shadycrew31
#1 Stunna
Shadycrew31's Avatar
59
Drives: 2014 335ix
Posting for a friend on the E90 group.
Please take the poll, I want to see how many people have done the OFHG or how many have had it done and if so, if their engines are still running. I know most N55 owners don't post here, but let's see.
      05-28-2019, 12:31 PM   #2
bimmer456
2966
Drives: 340i
The N55 is also in the F30. So they would post here.
      05-28-2019, 01:33 PM   #3
TheShadow
302
Drives: 335i M sport
almost all n55 owners post here.
      05-28-2019, 05:57 PM   #4
Jake From State Farm
Uhh... Khakis?
Jake From State Farm's Avatar
54
Drives: 2020 F250 Powerstroke
Replaced mine about 10K miles ago no problems.
      05-28-2019, 07:12 PM   #5
IK6SPEED
4490
Drives: BMW M3 / AH3
Lol...mine didn't lock up.....but app recorded it did.
      05-28-2019, 11:21 PM   #6
upsidedownfunnel
1999
Drives: 2014 335i
2014 BMW 335i  [0.00]
I changed my E60's N54 OFHG. Probably drove on the new one for about 30k miles afterwards without any issues. Engine ran great (other than requiring new turbos and HPFP under warranty and a new water pump).
Considering pretty much all N54/N55 (and many other BMW) engines need this service once before 100k miles, I don't think it's very common for engines to seize up after this service. Either someone grossly incompetent did the work, or it was just a coincidence.
amancuso725.50
      05-28-2019, 11:46 PM   #7
bimmer456
2966
Drives: 340i
That's not my definition of an engine running great if it's leaving you stranded and/or all that stuff needed to be replaced. Though I see other threads saying the same thing, how their car ran great except for needing a million things done either under warranty or otherwise, maybe DIY or whatever. Running great in my book means nothing other than regular oil changes and maintenance needs to be done.
      05-29-2019, 12:11 AM   #8
upsidedownfunnel
1999
Drives: 2014 335i
I was being half sarcastic. The turbos and HPFP were obviously issues with the N54. The N55 is far more reliable. Also, technically the car did always run fine. The turbos just caught the attention of a tech and they replaced them while I had it in for another service. And the HPFP just put me into limp mode one time. Restarted the engine and never gave me an issue again. BMW of course replaced the HPFP after that fault though. So it never left me anything close to stranded ever. I know though, that people who weren't more careful with maintenance often had much larger issues. I know sometimes anyone can get a lemon, but I believe that paying a lot of attention to maintenance makes owning a BMW a significantly smoother experience.
And regarding the water pump and gaskets. That's just part of owning a BMW. It's not ideal but whatever. You just have to consider them a maintenance item. There's a reason they had to use the parts they did and they couldn't figure out a cost effective way to make them more reliable. At least they made them really easy to change out. I have a theory that BMW says coolant is lifetime fill because every owner will inevitably be changing out the water pump before 100k miles and will thus be flushing their coolant.
Other than those "small" things, the engine was always great. IMO, it was smoother and more powerful than the N55, advertised figures notwithstanding.
      05-29-2019, 12:49 AM   #9
bimmer456
2966
Drives: 340i
I heard transmission was lifetime fill, didn't know coolant was also. I had to add coolant for some reason early on as that was an issue with the B58s but haven't had to since. The reservoir isn't sealed like the transmission, maybe they think you may need to add some due to evaporation even though it's not supposed to allow that to happen. They pressure tested it and said there wasn't any leak, and it hasn't indicated low coolant since. So far I'd say it isn't any worse than a toyota or honda. So far no limp home mode just low tire pressure which disables sport mode until you add air. Also had a runflat taken out by a pothole, was still able to drive even with a gash in the side of the sidewall until the next day when I had it replaced under road hazard coverage. So stuff that happens in any car.
      05-29-2019, 06:50 AM   #10
Mr Podman
221
Drives: 3 Series GT Stage 0.5
What'sa OFHG?
podman
      05-29-2019, 07:35 AM   #11
bimmer456
2966
Drives: 340i
Originally Posted by Mr Podman View Post
What'sa OFHG?
podman
Oil filter housing gasket. I had to look it up too.
      05-29-2019, 07:55 AM   #12
rbol13
24
Drives: 2014 335i M Sport
had mine changed a couple thousand miles ago at 39k, no issues so far as I can tell.
ER CP, more to be added. "Safety first then teamwork."
      05-29-2019, 11:54 PM   #13
neonnblack
139
Drives: 335i 6MT/e46 330xi
Changed mine last Thursday. All good.
i agree with someone seriously fucked up or the engine was on its way out already and just happened to be at the same time.
      02-07-2024, 01:35 AM   #14
f30jadyn
f30jadyn's Avatar
13
Drives: 2012 bmw f30 335i
Replaced mine. Engine siezed still trying to figure out wtf I’m gonna do lol.
      02-07-2024, 06:34 AM   #15
Revoltos
Revoltos's Avatar
53
Drives: BMW F30 335i
Replaced mine myself a couple of years ago. Pulled the injector plugs and cycled the engine on the starter for three cycles, probably 20 to 30 seconds in total of cranking after buttoning it all back up. No issues what so ever since.
      02-07-2024, 12:22 PM   #16
Fliplegend
Fliplegend's Avatar
1471
Drives: 2015 435ix F33
10K on my new valve cover, ofhg, oil cooler seal and intake manifold seals. Car is sitting at 70K.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line
      02-07-2024, 12:43 PM   #17
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
This is an old thread... but its probably a priming issue.
      02-07-2024, 03:28 PM   #18
Orion4
481
Drives: 2013 335i Sport Line Sedan
Replaced mine at 64K Now at 205k and getting ready to do again.
      02-12-2024, 04:26 PM   #19
Alek Melkonian
20
Drives: f30 and f15
Replaced mine at 120,000. Didn't even prime the oil system. Car is fine, 170,000 no issues.
      02-13-2024, 07:03 AM   #20
amancuso
amancuso's Avatar
726
Drives: 330it, 428ix, 430i
OFHG have been issues on BMWs for decades. This simple service should not seize an engine, unless it's incompetently installed and oil is leaking out of it like a geyser.
2016 428ix, r, 2018 430iC, 2018 330it
f30post
