05-25-2019, 02:05 PM | #1 |
BMW forever!
1389
Rep 2,418
Loose steering and handling after alignment
I just got my car aligned from the dealership.
The car feels loose and there is more vagueness in the steering response post alignment . It just feels less tight compared to before, however it tracks straight. All tire pressures look fine. One thing is that the dealership finished the alignment within 2 hours. Is this normal? What are the possible reasons for my car's vague feeling since alignment? I will try to post a before vs. after snapshot later today. Thanks!
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
05-25-2019, 03:23 PM | #2 |
2589
Rep 2,432
Drives: 2021 M2C
Are your tires old or new?
05-25-2019, 05:12 PM | #4 |
BMW CCA Member
488
Rep 808
What are your alignment numbers?
Alignment is sort of an art form. And just because a tech's be trained on alignment, doesn't mean they are very good at it. Generally BMWs like a little toe in in the front and back. So if you look from the top of the car down, the tires look like this... / \ . If it's too loose or vague, I *think* it might be because there isn't enough toe-in so the tires look like this | |. |
05-25-2019, 08:54 PM | #5 | |
BMW forever!
1389
Rep 2,418
2020 BMW X5
05-25-2019, 08:56 PM | #6 |
BMW forever!
1389
Rep 2,418
Here's another spec from a different dealership done last year in August.
This spec gave a much tighter feel.
2020 BMW X5
05-25-2019, 11:28 PM | #7 |
BMW CCA Member
488
Rep 808
Hmmm... found this thread. I assume you are working on your M2?
On my old M3, toe numbers needed to match both sides (to the tenth) or else the steering would feel vague. Comparing your old alignment specs to these below, that little .01 and .02 difference is what you are feeling. https://f87.bimmerpost.com/forums/sh....php?t=1350367 |
05-26-2019, 01:19 PM | #8 |
1508
Rep 1,387
The only thing I see is less overall toe in the latest figures. As you get nearer parallel steering feel often goes vague.
I did notice that when you took the car in it had too much rear camber on one side. Ours was the same and was very twitchy until I got it realigned at a top notch local shop. |
05-26-2019, 08:53 PM | #9 | |
BMW forever!
1389
Rep 2,418
2020 BMW X5
05-26-2019, 08:54 PM | #10 | |
BMW forever!
1389
Rep 2,418
2020 BMW X5
05-27-2019, 04:42 AM | #11 |
6659
Rep 15,858
I'm with the front toe setting as well. It's about half the target value. Explains both lightness and vague on-center feeling.
