Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Rear Suspension Metal Clank, Tips on Subframe, Wishbone, Toe and Trailing
      05-24-2019, 07:05 PM   #1
Demz760
45
Drives: 2009 E90
2009 BMW 328i  [0.00]
2012 BMW 335i  [0.00]
Edit: Problem solved, replaced e-brake / parking brake, noise gone.
So I have a pretty loud metal clanking noise coming from the rear, and Im starting to replace things.
Car has 55k miles, is this a normal mileage to need replacement?
Replacing the the Wishbone, Toe and Trailing arms, upper / lower shock mounts, Stabilizer Bar Links in the future if all else fails.
I now have access to a lift and any tools, was using jack stands and floor jack before.
Can you guys help me match these arms with the respective torque specs?
Thanks appreciate any help!
18: TOE ARMS
15: GUIDE?? ARMS?
16: WISHBONE
14: TRAILING ARM??
17: CONTROL ARM
4: Torque specs?
12: Torque specs?
Am i correct?
Renewed nuts/bolts.
x2 # 12 Hexagon screw with flange M12X1,5X67-10.9 07119906489
x3 # 13 Self-locking collar nut M12X1,5-10 ZNS3 33326760668
x2 # 15 Securing bolt M12X1,5X74-10.9 33306793891
x1 # 16 Eccentric bolt M12X1,5X125 33326764292
x1 # 17 Eccentric flat washer 33306786186
5/31/19 Edit: Parts In:
2012 BMW 335i E92 2009 BMW 328i E90
      05-25-2019, 10:48 AM   #2
feuer
feuer's Avatar
4276
Drives: wife crazy!
I suggest you find what is causing the clunk before you start replacing good parts only to find clunk persist. Those circled in red/blue rarely go bad. Usually is the other end and that bushing is on the spindle. Could be also the quide or tension rods. Or the shock or shock mounts. I doesn't matter if e90 or e92, or 328i or 3335i, they are all the same.
      05-25-2019, 11:25 AM   #3
weehe126
1161
Drives: 2017 340i
Two times I've had a rear clank were from the aftermarket dif brace and when one of the rear shock mounts went bad. The inset in the rubber mount failed and it was moving around. Doubt it's from anything you've circled.
      05-26-2019, 01:55 PM   #4
Demz760
45
Drives: 2009 E90
Thanks, I already received a new set of Camber, Toe and Trailing arms, just going to throw them on and go from there. You got me thinking though It may be something to do with the shocks / mounts. That will probably be the next thing I replace.
No dif brace, noise comes from both sides, was it the lower mounts? http://www.strutmonkey.com/store/p34...Mount_Kit.html
The upper mounts should still be good right? No snow/salt/ 55k miles:
http://www.strutmonkey.com/store/p35...Mount_Kit.html
Thanks!
Edit: Heres what I ordered:
ACDELCO - 45F2033 - Knuckle Bushing x2 (not messing with subframe just yet)
KYB - SM5767 - Lower Shock Mount Kit x2
MOOG - K160366 - Upper Shock Mount Kit x2
Order Total $102.05
Not bad...
      05-27-2019, 10:22 PM   #5
weehe126
1161
Drives: 2017 340i
Yes, I was referring to the lower mounts. So it comes from both sides consistently?
      05-27-2019, 11:11 PM   #6
Demz760
45
Drives: 2009 E90
If you hit a bump on the left side only you hear the clank on the left only, and right is the same as well.
The left side does seem to be worse.
      05-28-2019, 10:59 AM   #7
weehe126
1161
Drives: 2017 340i
Have you replaced your sway bar end links, front or back?
      05-28-2019, 12:24 PM   #8
Demz760
45
Drives: 2009 E90
I have not, yet...
      05-28-2019, 03:56 PM   #9
weehe126
1161
Drives: 2017 340i
I have not, yet...
Most likely the cause. Check them first.
      05-30-2019, 09:57 PM   #10
Demz760
45
Drives: 2009 E90
The rear sway bar end links look to be in pretty good shape. Most of my parts came in today, still waiting on Upper Shock Mount Kits to be delivered tomorrow.
Ready to throw this car on the lift and get wrenching either late Tomorrow or Saturday morning.
Ready to throw these in tomorrow.
      06-02-2019, 03:37 PM   #11
Demz760
45
Drives: 2009 E90
Swapped out the parts, noise still there... :/
Ordered Swaybar endlinks express shipping... coming in Tuesday. I hope this is it.
      06-05-2019, 09:31 PM   #12
Demz760
45
Drives: 2009 E90
Replaced them, they were shot... yet Noise is still Fing there... getting annoyed now.
      06-06-2019, 09:24 AM   #13
weehe126
1161
Drives: 2017 340i
Just the rear links or also the front? Did you check the shock mounts?
I see you replaced the mounts. Subframe bolts loose?
      06-06-2019, 10:02 AM   #14
feuer
feuer's Avatar
4276
Drives: wife crazy!
Sorry but I told you in post#2. All these parts and labor and clunk persist. When does the cluck happen? Only when you hit portholes? Have you checked the diff and half axles?
      06-06-2019, 07:38 PM   #15
Demz760
45
Drives: 2009 E90
I did only the rear links, Subframe bolts were all torqued down, nothing loose. Mounts are done and torqued.
Yeah but what I took off was pretty worn already, so doesn’t really hurt considering they weren’t all that expensive.
It happens on bumpy roads, holes. Noticeably after the rear wheels roll over something.
Thanks I’ll check out the diff and axles this weekend.
Is it possible the rear e-brake could cause a rattle?
      06-06-2019, 09:42 PM   #16
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
I located my clunk by putting car on ramps at rear and got under while another guy bounced rear axle for me. It was a lower attachment to shock. I have M3 lower camber arms with M3 style coil overs. I had the bolt spacers reversed on driver side. The sweetest fix is the free one. I agree with feuer that you should diagnose the problem and stop changing numerous parts.
Appreciate 3
feuer4275.50
ornicar136.00
      06-07-2019, 09:34 AM   #17
weehe126
1161
Drives: 2017 340i
If the rear links were shot the fronts definitely are.
      06-09-2019, 05:25 AM   #18
ornicar
ornicar's Avatar
No_Country
136
Drives: 125i
It may be the diff:
https://www.e90post.com/forums/showthread.php?t=175885
      06-09-2019, 01:57 PM   #19
weehe126
1161
Drives: 2017 340i
Originally Posted by ornicar View Post
No mention of on/off gas clunk.
      07-11-2019, 10:03 PM   #20
Demz760
45
Drives: 2009 E90
Finally replaced the rear e-brake pads and noise is gone!
      07-11-2019, 11:39 PM   #21
weehe126
1161
Drives: 2017 340i
Well, props to you on finding the most unlikely culprit.
      07-23-2019, 05:14 PM   #22
ornicar
ornicar's Avatar
No_Country
136
Drives: 125i
Hey,
can you please explain us which part did the noise in the e-brake?
Thanks
