M3 rear guide rods - feedback?
05-24-2019, 05:03 PM | #1 |
Cometh
1090
Rep 1,305
Drives: Boy's Soul
Does anyone have any feedback on M3 rear guide rods? Based on the findings from this thread, they seem to be a worthwhile upgrade and also easy to install, but I haven't been able to find any detailed reviews.
My other suspension modifications: - 235/45R17 Pirelli Pzero AS+ - Sport springs w/ Bilstein B4 - 28mm front sway bar - front M3 tension struts - rear poly sway bar bushings - rear poly subframe inserts - Monroe rear upper shock mounts - front + rear M3 subframe bracing |
05-24-2019, 05:59 PM | #2 |
2183
Rep 2,806
I think they are worthwhile and a pretty easy install. The back end of my car is certainly more controlled and more precise feeling, BUT, I did the guide rods at the same time as Whiteline RSFB inserts and firmed the rebound on my Koni Yellows. So how much improvement came from what is hard to say.
I don't know how much is due to guide rods, but, according to the post you referenced, M guide rods + toe control arms have the effect of lowering rear spring rate by 72 lb/in. My guess most of that reduction is due to the toe arm as that replaces 2 bushings.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
The Nightman1090.00 |
08-11-2019, 03:37 PM | #3 |
44
Rep 47
Hey guys.
We have manufactured rear toe arms for the e82 and e9x non-M. The design principle is a curved arm, but with dimensions better suited to the non-M suspension. These are made of billet 6061-T6 aluminum and have been precision CNC machined to accept either balljoints or bushings (which can be either stock bushings or much stiffer Group N bushings, or even polyurethane bushings like those from Powerflex and other suppliers), or any combination of balljoints and bushings depending on individual preferences. They can be anodized in any colour. They can also be made either in the standard length (412 mm) or +3 mm for extra toe. Because you can select balljoints or bushings, or any combination, you can tweak your effective spring rates in increments (measured in lb/in). So, for example, on effective spring rates: - 2 balljoints: 0 - 1 balljoint and 1 regular bushing: 15 - 2 regular bushings: 30 - 1 balljoint and 1 Group N: 56 - 1 regular bushing and 1 Group N: 71 - 2 Group N: 112 Assuming the contribution of a full set of stock bushings is an equivalent of 109 lb/in, then that can be fully compensated with a set of MRP toe arms with 2 Group N bushings, and the other 4 arms can be only balljoints... Just trying to gauge interest at this point so please reply if you might be interested in this product... a Stay tuned! Last edited by Angel67; 08-11-2019 at 03:41 PM.. Reason: Adding pic |
WatchWolf34126.00 lab_rat394.50 |
01-14-2020, 12:39 PM | #4 |
18
Rep 167
I've bought a pair of M3 rear guide rods to install on my 335i. The torque specs say to torque them down to 100 NM for bodyside and 100 NM + 90 degree to wheel under load. It says to also replace these nuts and bolts. Do we have to replace them? Is it necessary? They aren't aluminum bolts right?
01-15-2020, 01:41 PM | #7 |
Because Racecar
126
Rep 266
What are you defining as "worthwhile"?
Seems to me that the M3 guide rods will soften the effective spring rate based on that thread you shared. Are you looking to reduce oversteer?
01-16-2020, 07:44 AM | #8 |
1903
Rep 6,968
So, when you guys say M3 rear guide rods, are you saying the rear tow arms on the very bottom of the rear subframe?
I thought the M3 version was too short, so 335i owners can't use them? |
01-16-2020, 08:48 AM | #9 |
4276
Rep 9,206
You are talking about the toe link, M3 378mm vs non-M 412mm, the rest are all same length.
01-16-2020, 09:54 AM | #10 | |
1903
Rep 6,968
feuer4275.50 |
01-16-2020, 09:55 AM | #11 | |
1903
Rep 6,968
01-16-2020, 12:59 PM | #12 |
3058
Rep 3,910
01-18-2020, 04:47 PM | #14 |
18
Rep 167
motion on one end
The red circled bushing on my upgraded M3 guide rod has some motion/play while my stock 335i guide arm has no motion. Is that normal? I was wondering if the red circled bushing is shot?
01-18-2020, 05:36 PM | #15 |
3058
Rep 3,910
That one is a ball joint, unless I'm mistaken. It should move relatively freely (unlike a rubber bushing), but shouldn't have any radial play at all.
01-18-2020, 06:13 PM | #16 | |
18
Rep 167
01-19-2020, 02:06 AM | #17 |
3058
Rep 3,910
If you move one side of the joint down and the other goes up, that's fine; it should swivel.
If you can move it in the directions you showed, but keeping the joint perpendicular to the arm, that would be bad. You should be able to move the joint by hand, probably, but it shouldn't be loose. |
01-21-2020, 02:45 AM | #19 |
87
Rep 236
Drives: e92 335iA
I have changed all those M3 parts bit by bit and I can state that they (these rear M3 rods) do improve maybe like 10% (and we are talking about vehicle with 160k miles)... much greater impact made change of subframe bushings (again M3)... but to get rid of "rear WOT steer" effect I had to put on the diff brace...
new rear shocks, rear M3 roll bar, all M3 bits, rigid toe arms and it was still not planted... diff brace made it stable, don't ask me why cause it doesn't make much sense to me...
"If everything seems under control, you're not going fast enough.” Mario Andretti
01-21-2020, 02:14 PM | #21 |
3058
Rep 3,910
01-21-2020, 02:43 PM | #22 | |
4276
Rep 9,206
