Shift point
08-06-2008, 11:13 PM | #1 |
11
Rep 133
Shift point
Hi guys,
I just bough a E90 335i and will start tracking it soon (once it is broken in...) A question though: Judging from the spec sheet of our car, I think shifting at around 6000RPM rather than winding it out to redline is more efficient, and may even help with cooling. Is this observation correct? (btw, I am an experienced track driver, albeit with other cars...
*Ultimate* mod for the car: a better driver...
08-06-2008, 11:15 PM | #2 | |
75
Rep 1,288
Drives: 135i
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
08-08-2008, 01:18 PM | #4 | |
52
Rep 1,714
You need to map out the dyno for your specific car and apply gear ratios. What you're trying to determine is the TORQUE TO THE GROUND, which is very dependent on gearing. The engine torque gets multiplied by both the gearbox and the rear end. In other words, if you're putting out 300lb-ft from the engine and you are in 1st gear, you are putting 300 x 4.06 (1st gear ratio) X 3.08 (rear end ratio) = 3751.44 lb-ft to the ground. The proper way to calculate the right place to shift is to determine how much torque TO THE GROUND would be achieved by shifting and how much is achieved by staying in the same gear. In the lower gears (1-2, 2-3), the percentage difference in multiplication is huge (change in gear ratios is large), so it behooves you to shift later. Basically you are balancing the loss in torque at higher engine rpms (note how the torque curve trends down at high rpm) with the loss in gear multiplication from upshifting. For my 6MT car, I applied my dyno results (Procede) and got the following: 1-> 2 ......6700rpm 2-> 3 ......6500rpm 3-> 4 ......6150rpm 4-> 5.......5850rpm 5-> 6 ......5800rpm Note that it will change based on your specific engine output, which is dependent on what tune, if any, you have. But this is a good baseline. |
08-09-2008, 12:11 AM | #5 | |
Something Else
24
Rep 216
Roy
DFtrac adjustable rear swaybar (335i coupe)
http://www.gambitmotorsport.com/rearswaybar.html |
08-09-2008, 12:19 AM | #6 | |
40
Rep 1,657
there's two equations you can apply and they both give the same results. 1) you can find the gear 1 rpm where: torque, multiplied by the gear ratio of gear 1, in gear 1 = the torque, multiplied by the gear ratio of gear 2, if shifted to gear 2 or 2) you can find the rpm where: the power in gear 1 = the power in gear 2, if shifted to gear 2 either one will produce the same results. if you search this forum, you will find that someone has already done the math for a stock 335. gear shift rpm gear 1 - redline gear 2 - redline gear 3 - 6700 gear 4 - 6400 gear 5 - 6400
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production |
08-09-2008, 12:21 AM | #7 | |
40
Rep 1,657
that chriping effect happens on all cars, not just turbos, if you shift where it drops you near the torque peak in the next gear. not sure if shirping makes it accelerate faster tho
08-09-2008, 12:31 AM | #8 | |
Something Else
24
Rep 216
I do think the turbos have a little to do with it, though - at least, on a modified set-up. Just put in the clutch and let the accelerator go at different RPMs and hear the difference in the spool-down. Roy
