Bimmerpost
4 Series
Technical Topics Cosmetic and Lighting Modifications (exterior & interior) Tow hook license plate mount?
      04-01-2019, 02:37 PM   #1
HapkidoNinja
HapkidoNinja's Avatar
42
Drives: 2020 M340i xDrive
Does anyone know if these are available for the M340i w/sensors?
My "go to" shop has not replied to my email query and I'll be damned if anyone at the dealership is going to take a drill to my baby when it arrives.
Still calling around, and if I hear something I will update the thread.
      04-01-2019, 03:23 PM   #2
alex2364
alex2364's Avatar
2862
Drives: 2020 M4 ZCP / 2023 X3 M40i
2020 BMW M4  [10.00]
2023 BMW X3 M40i  [10.00]
Just contact the manufacturers. I would get in touch with US Mill Works directly. www.usmillworks.com
      04-01-2019, 10:37 PM   #3
hans007
605
Drives: 2020 BMW M340i
i have one of these for an f30. and it would set off the park distance control sensors right near the tow hook hole. I hope they have figured out a way around that
      04-01-2019, 11:56 PM   #4
Wineguy
22
Drives: M535,328i,328d,330i
Spoke to my CA he said they would set off sensor. Suggested I put tape over sensor. I ordered the toe hook license plate mount anyway. Will probably remove front plate.
      04-02-2019, 07:47 AM   #5
alex2364
alex2364's Avatar
2862
2020 BMW M4  [10.00]
I had one on my F82 briefly and I was able to adjust it without setting off the parking sensors.
      04-05-2019, 02:33 PM   #6
HapkidoNinja
42
I used their product on my F30 in the past and it was fine. I reached out to them 2 weeks ago, they have yet to respond - they are notoriously bad at email. No "Enter" key on their keyboards....
      04-05-2019, 02:37 PM   #7
HapkidoNinja
42
I am guessing that I can reposition the mount plate in a way that will make it work once I know what the position of the sensors is relative to the tow hook.
Unless they add multiple sensors spaced 6 inches apart....
In either case I have been clear with my CA, NO FRONT PLATE!
      04-05-2019, 02:38 PM   #8
HapkidoNinja
42
USMillworks had a great rig which was perfect on my F30 (2014 335i MSport w/PDC). If you got the wrong model then it wouldn't mount in the same position and would not have been fun.
      05-23-2019, 09:32 PM   #9
bimmer2023
Drives: 2019 bmw 330xi
hey guys has anyone found or is using the front tow hook plate bracket. I have been looking to buy one but I do not think anyone makes it for our vehicle yet.
      05-27-2019, 08:56 PM   #10
g20beam
g20beam's Avatar
475
Drives: G20 330i M Sport
2019 BMW  [0.00]
I found a universal one on Amazon. The F30 ones will work on the G20, at least the tow hook is the same.
You want to beware and find one where you can screw the bracket as far to the left side of the car as possible, otherwise your front sensors will be blocked and it will trigger every time light shines on the plate, reflected onto the sensor. So, preferably one with plenty of holes on the bracket piece.
If you want to see pictures, go visit my IG account. (g20beam)
      06-06-2019, 04:10 PM   #11
gazoo001
Puerto Rico
Drives: 2020 M340
which universal one from Amazon?
I got the new M340 but I have still to find one
      06-06-2019, 04:14 PM   #12
vicfalc09
vicfalc09's Avatar
211
Drives: M340i xDrive
PARTS@STBMW
https://www.bmwpartspros.com/partloc...catalogid=8798
      06-06-2019, 05:32 PM   #13
gazoo001
Puerto Rico
Drives: 2020 M340
where you able to find a plate mount that works for the M340?
      06-07-2019, 07:24 AM   #14
phillyd2
218
Drives: 2020 M340i XDrive
If you live in a State that requires a front plate then why the hesitation to drill the holes? They already drilled holes in the back?
      06-16-2019, 12:06 AM   #15
HapkidoNinja
42
US Millworks towhook license plate mount won’t fit - which one will?
I tried to use a kit for the G20 from US Millworks, as their quality is awesome and I used to have one before. Unfortunately, on the G20 the towhook bolt is too short to clear the bumper fascia.
Has anyone found a license plate mount for the M340 that fits?
      06-21-2019, 10:31 AM   #16
MassBimmer
MassBimmer's Avatar
No_Country
306
Drives: 2023 i4 M50
2009 BMW  [9.24]
I purchased the Rennline bracket for my M Sport and it clears but interferes with the parking sensors. I've disabled the sensors from automatically activating so that it doesn't beep while driving but it's still a bit of a pain
https://www.ecstuning.com/b-rennline...e10701340~rel/
      06-23-2019, 07:58 PM   #17
Prose1
Drives: BMW M340i X Drive
https://www.amazon.com/dp/B07PMLY2CH..._S5beDbV8FBF0Y
I have mounted this one , fairly simple to do but i’ve yet been able to adjust it so that it doesn’t trip the PDC
      06-25-2019, 03:39 PM   #18
Bmwguy1994
Bmwguy1994's Avatar
24
Drives: M5 Comp(15)/435xi MSport(16)
not a tow hook bracket but this would work and what I am considering as I see no other viable options. If anyone else has any idea on how to solve this dilemma the info would be highly appreciated.
https://bigmikesperformanceparts.com...ct-description
      06-25-2019, 03:41 PM   #19
Bmwguy1994
Bmwguy1994's Avatar
24
      06-30-2019, 10:50 AM   #20
Prose1
anonymous image hosting
Figured it out , ended up having to go with a Sly Bracket , Folded the license plate as well to reduce the width on it.
https://www.slybrackets.com/
Tow hook mounted brackets will not work if you have PDC.
      07-01-2019, 02:57 AM   #21
Glassy
E36, E46, E90, E92, F32
Glassy's Avatar
97
Drives: G20 M340i
Just got mine,
      07-08-2019, 08:15 PM   #22
Pauleebe
Pauleebe's Avatar
380
Drives: Inbetween BMW's.
Emailed them and hope to hear back.
Tags
license plates, towhook
g20
