brake service keeps popping back up!!
05-23-2019, 06:58 AM | #1 |
Rep 20
so ive already replaced all the brake /abs sensors and the pads are in good shape. i reset the service light and a couple days later it pops up again for the front and back! its really annoying! anyone had this issue if so whats the proper way to fix it? thanks
05-23-2019, 10:11 AM | #2 |
21
Rep 105
bad connection from the sensor to connector or cheap aftermarket sensor will do this . it happened to me after changing front brake pads
05-23-2019, 11:11 AM | #3 |
145
Rep 506
And this is why I don't bother with these useless sensors. I rolled mine up and tucked them away so I will never have to bother with changing them or have any service light.
2010 335I Xdrive
You're not really driving if you don't have 3 pedals. |
05-23-2019, 05:00 PM | #4 |
1085
Rep 1,677
The sensors have to see continuity. Bad connections will do that.
New the sensors have continuity (0 ohms), and when nearly worn, it will show about 200 ohms. I guess between the two CBS can calculate the pad wear rate and give more definitive time and mileage to replacement point. I run 2 sets of pads per rotor change, and on the second set the light will come on way early. Therefore, I too cut off an old sensor near the connector and tie the two wires together. Some senior members on the forum will scold you for that. That being said, for others' cars I always use new sensors and they can put up with the warning light for safety reasons. |
05-24-2019, 07:07 AM | #5 |
17377
Rep 18,773
You haven't been clear on exactly what you did and how you did it for the recent brake work. You said you replaced the "ABS" sensors. ABS sensors are not the pad wear sensors, so I first want to make sure you just didn't have a typo; if you did really replace the ABS sensors, then you replace the wrong sensors. The pad sensors are just two (2) per car and cost about $20 each. ABS sensors are four (4) per car and are about $90 each. So you didn't explain how you replaced "all the brakes". When you replaced the brake pads, did you replace the pad sensor in the left front brake on the inner pad and the sensor in the right rear brake inner pad, and plug the sensors into there respective connectors? Also, did you follow the correct cable routing to prevent breakage of the new sensor harnesses?
If you properly replaced the pad wear sensors did you reset the system at that time? Did you know you had to reset the system back then, or did you just discover the system needs to be reset at the time the pad sensors are replaced? If you did not reset the system when you replaced the pad sensors, and the sensors had reached the 2nd stage of wear, adding new sensors, would confuse the CBS. I suggest, either (a) replace the brake pad sensors again and reset the system, or (b) just unplug both brake pad sensors from their connectors, then reconnect them, and reset the CBS.
05-24-2019, 07:14 AM | #6 | |
17377
Rep 18,773
If one properly maintains the BMW E90 3-series brake system in accordance with BMW service specifications, you'll never have an error with the pad wear light. But if you are a dumbass, you will .
05-24-2019, 10:42 AM | #8 |
17377
Rep 18,773
You can use the stalk method, just like when resetting the oil service indicator.
05-30-2019, 07:58 PM | #11 | |
2124
Rep 2,758
Either need to get a custom tune to get rid of them, or use a DP fix(but this should only be used when trying to pass an emission test and not year round) |
