05-22-2019, 08:49 AM | #1 |
Rep 12
Keyless Ignition will not start engine after dashboard change
So i have an F32 which required a dashboard change after the airbags were deployed. After the change, i noticed a few weird things.
1. Windows wouldn't dip when opening and closing the door. This was rectified by a general window reset (holding it up and down for a few seconds). 2. Navigation Monitor doesn't work. Although i believe this was an issue before the dashboard was changed. I upgraded from the 6.5" to the 8.8". There is power going to it as the backlight turns on when the ignition is on, however it stays completely blank/black. 3. The keyless ignition system doesn't read my key anymore. Key works fine for opening and closing the car, however when inside, it will always prompts me to hold the key up to the steering column, and after a few tries with it there it turns on. My suspicion is, when i put the new dashboard back in, I've either shorted a cable or I've somehow damaged the sensor. Unfortunately I don't know where the sensor is located otherwise i'd have a look. Also it's worth noting that during the change i didn't disengage the battery, it was on at all times. This was due to it being very difficult turning it back on if the boot closed and it being a multi-day project, i couldn't leave it open for so long. Any guidance or advice would be very appreciated. It's doing my head in trying to figure it out |
05-22-2019, 04:53 PM | #3 |
Rep 12
05-23-2019, 07:16 AM | #4 |
BMW CCA 69606
86
Rep 227
Put a 10-15 amp charger on the battery over night and replace battery in key.
Check system voltage with engine running. Put ISTA on a laptop, buy ENet cable and interrogate car. Several DIY installs available for ISTA. Run test plan for codes. |
Syc01.00 |
05-23-2019, 08:00 AM | #5 | |
Rep 12
2. I'll do the voltage check as advised. 3. I just bought an Enet cable to code battery and 8.8" screen, so i'll do as you advised and run some tests. Thankyou for your response |
05-23-2019, 05:46 PM | #6 |
Rep 12
After running diagnostics on ISTA, i think i found the culprit.
fault 804107 : Aeriel in passenger compartment, front: line disconnection I am now trying to locate the aerial that controls the keyless function. I may close this thread and start a more specific one. |
05-23-2019, 09:42 PM | #7 | |
4488
Rep 10,473
That's where the front sensors are...right around the shifter. |
Syc01.00 |
05-24-2019, 02:48 AM | #8 |
Rep 12
I did infact remove majority of the centre console trim to remove the dashboard. I'll have a look there and see if anything out of place.
05-24-2019, 11:05 AM | #10 |
Rep 12
05-24-2019, 03:57 PM | #11 | |
Rep 12
Genuinely do appreciate the time you spent to show me where the fault was. |
05-24-2019, 04:15 PM | #12 |
BMW CCA 69606
86
Rep 227
Psssst.....he wants you to push the greyed out "Appreciate" button in lower left corner of post........Hover over button and it will illuminate.
05-25-2019, 06:24 PM | #13 |
Rep 12
