BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > M3 vs Non-M Front Subframe
      05-21-2019, 06:57 PM   #1
Justin Daniels
Justin Daniels's Avatar
57
Drives: 2011 128i
2011 BMW 128i  [0.00]
I have found lots of information on the REAR subframe differences, but nothing on the front. Are the suspension mount points all in the same position and the only differences clearly visible (bar under engine, integrated bracing to right behind the front wheels)?
I have an entire M3 worth of subframes/arms/diff/axles/uprights/coilovers going under my 325i and it turns out the M3 subframe is tweaked a bit, so I'll just run the 325i unit if it's dimensionally the same.
Thanks in advance
Cheers,
Justin
      05-25-2019, 10:40 AM   #2
feuer
feuer's Avatar
4276
Drives: wife crazy!
Chassis mounts yes. Suspension mounts yes. Engine mounts no. So no use unless installing a v8 in your car.
      05-26-2019, 09:22 PM   #3
Justin Daniels
57
Drives: 2011 128i
That's what it looked like when I laid one atop the other, but wanted to confirm.
I am installing a V8 but not the M3 lump. I'd rather keep the N52/54 subframe in case I ever want to make the car CCA legal.
Thanks.
      12-24-2019, 09:03 AM   #4
grafton
England
Drives: 2008 E90 335d
hi,
do you know if i could use a 2009 318i petrol front subframe on my 2007 E90 335d?
thanks
      12-24-2019, 09:46 AM   #5
Soravia
114
Drives: 2011 E91 Silver xDrive 6MT
Originally Posted by grafton View Post
hi,
thanks
Use www.realoem.com to compare
      12-24-2019, 10:09 AM   #6
grafton
England
looks like the same front subframe for all e90 models except the V8 M3 model
      12-24-2019, 02:56 PM   #7
bbnks2
1207
Drives: 135i N55
That's a good point. Never thought about engine mounting.
You would want a 1M subframe. Has anyone actually confirmed that the pickup points are all exactly the same? OP can you verify that?
      12-24-2019, 07:46 PM   #8
feuer
feuer's Avatar
4276
Drives: wife crazy!
Why front 1M subframe? Is shared with all non M RWD models.
      12-27-2019, 10:44 PM   #9
bbnks2
1207
Drives: 135i N55
Yepp 31116785639
So you can say that there is no " M car upgrade" available. 1M uses the same subframe as every other 1 series.
      12-28-2019, 07:14 PM   #10
feuer
feuer's Avatar
4276
Drives: wife crazy!
Yepp 31116785639
The front yes, the rear is 100% m3 subframe
bbnks21206.50
      12-31-2019, 05:39 PM   #11
The Nightman
Cometh
The Nightman's Avatar
1090
Drives: Boy's Soul
The "upgrade" is the solid panel that reinforces the subframe:
It won't fit non-M subframes but I replicated it by using the same mounting points for my own bracing. It reinforces the tension strut and wishbone mounts. It was more of an experiment but I couldn't believe the difference it made. Biggest surprise was the reduction in NVH gained from the M3 arms. The factory underbody panel still fits too.
Appreciate 8
feuer4275.50
ornicar136.00
tetsuo1111227.00
Biginboca3763.50
DLag30103.50
E92only82.00
      12-31-2019, 09:20 PM   #12
ornicar
ornicar's Avatar
No_Country
136
Drives: 125i
Very interresting! specially for the NVH reduction feedback.
The OEM answer could be the V brace from E88, no?
https://www.1addicts.com/forums/show...751&page=2
      01-01-2020, 12:33 AM   #13
The Nightman
Cometh
1090
Drives: Boy's Soul
I believe the rear most mounting point interferes with the existing brace, and the undertray likely won't fit with the front bracket installed
ornicar136.00
      01-01-2020, 02:29 AM   #14
ornicar
ornicar's Avatar
No_Country
136
Drives: 125i
https://www.realoem.com/bmw/enUS/sho...diagId=51_7043
there is a specific underhood for the E88
      01-09-2020, 10:26 PM   #15
tlow98
2188
Drives: 2009 E91, 2014 F15 x35i
Awesome! Just curious but what keeps the M3 panel from fitting? The exhaust?
      01-10-2020, 11:32 PM   #16
The Nightman
Cometh
1090
Drives: Boy's Soul
The stock black bracing interferes with the rear mounting points of the M3 plate. The stock brace cannot be removed because it connects the non-M subframe to the chassis. The M3 subframe is directly mounted to the chassis.
      01-12-2020, 04:51 PM   #17
tlow98
2188
Gotcha. Are the inserts already there for the M3 brace or did you insert your own? Or nut/bolt it?
      01-13-2020, 12:21 AM   #18
The Nightman
Cometh
1090
Drives: Boy's Soul
You need four rivnuts (07147199279) and M10 bolts
https://www.fcpeuro.com/products/bmw...ut-07147199279
Appreciate 2
tlow982188.00
DLag30103.50
      01-25-2020, 06:25 AM   #19
streetpro
streetpro's Avatar
Czech_Republic
87
Drives: e92 335iA
Great info .-) Does the engine splash guard fits afterwards or did you have to make any changes iot to fit?
Thx
      01-25-2020, 01:24 PM   #20
The Nightman
Cometh
1090
Drives: Boy's Soul
Thx
Factory underpanel fits perfectly, but it will depend on the thickness of the metal stock used. My brace is about 3/8" thick
ornicar136.00
      07-22-2020, 11:34 AM   #21
ornicar
ornicar's Avatar
No_Country
136
Drives: 125i
Do you know why 1 series E82 don'h have this V black bracing?
My idea is that maybe we (1 serie owners) could fit the thorough M3 Reinforcment plate (without cut). It would be great
Thanks
      07-22-2020, 11:43 AM   #22
ornicar
ornicar's Avatar
No_Country
136
Drives: 125i
For information the brand of this Nut is Bolhoff RIVKLE HRT
You can buy it for cheaper than at BMW.
https://eshop.boellhoff.de/en/Riveti...ce-Thread.html
