Combox Retrofit Help
05-20-2019, 06:05 PM | #1 |
185
Rep 780
I am trying to code combox retrofit onto my friends 2011 335i and running into a few problems specifically with the SOS warning. Steps I did below:
Car build date: #0310 (Did not change build date) Delete $633, $612, $616 (Car did not have any of these in vehicle order to begin with) Add: $614, $615, $644 (Would not let me add $644); $6AL; $6FL; $6NF; $6VC; $6NR; $7SP Default coded CIC and Media. Bluetooth audio streaming and phone pairing was working fine but USB media and charging was not working. My friend installed the usb port and ran the line from the Combox but he believes that the line might've been the wrong one so he ordered an oem one, the VO for USB is there so I assume the coding is there. Connected drive is not on the screen and Office is there but only has phone book within it. Shouldn't connected drive be an available option now? As for SOS Malfunction. I added +TELD to CAS and default coded KOMBI and CIC but the fault remained. Do I have to default any other modules? I tried default coding ECALL and ABG but both failed for some reason. Any info on how to get the SOS malfunction off? The other modules in the list are 2JBBF, 63BMO, ABG, AFS, CAS, CIC, CID, DSC, DWAI, DWAS, ECALL, EKP, FAS, FZD, IHK, KOMBI, LSCMC, MEDIA, NFRM PDC, PGS, RDCLC, RLS, RSMC, TGBT, TGFT, ZBE. |
05-20-2019, 08:55 PM | #2 | |
1458
Rep 1,912
For the combox delete $639 and add $644, $6vc, $6fl. If you want bmw apps you need $6nr and a fsc code on the cic. Take any aftermarket Hsd cables and throw them away. Only use oem hsd cables. That is why your buddies 6fl is not working. |
05-21-2019, 05:36 PM | #3 | ||
185
Rep 780
05-21-2019, 05:51 PM | #4 |
357
Rep 1,724
Code the Kombi module
TCM_ALIVE_MONITOR -> nicht_activ TCM_ID_MONITOR -> nicht_activ or COMBOX_ALIVE_MONITOR -> nicht_activ COMBOX_ID_MONITOR -> nicht_activ
'09 335D
05-21-2019, 05:52 PM | #5 |
1458
Rep 1,912
05-21-2019, 07:36 PM | #6 |
263
Rep 1,173
05-25-2019, 04:23 PM | #7 | ||
185
Rep 780
05-26-2019, 05:11 PM | #8 |
1458
Rep 1,912
