Bimmerpost
4 Series
Technical Topics Wheels and Tires 18" on 2020 M340 xDrive
      05-18-2019, 05:51 PM   #1
tyaremko
Drives: 2020 BMW M340i xDrive
Recently bought a 2020 m340i xDrive and it came with 19" stagered wheels with 255/35r19 in rear and 225/40r19 in the front. Before ordering winter wheels is there anything I need to know. I want to go down to 18'' for my winter set so do i just go 255/40r18 and 225/45r18, if so what are the exact wheel specs that are needed, width and offset for the front and rears.
I noticed the BMW 796M wheel comes in 18x8.5 et40 and 18.7x5 et25, is this the spec i want
Also where is the best Place to order OEM bmw wheels in north America
      05-21-2019, 01:15 PM   #2
sanch8
67
Drives: 2019 330i
Based on what i have read on the F30 forums, most people prefer a straight setup for winter for a more balanced handling. If you are going with 18" aftermarket wheels, both 7.5"J or 8"J wheels will work with 225s.
      07-23-2019, 04:52 AM   #3
WXdrivefun
WXdrivefun's Avatar
278
Drives: G20 330Xdrive
@tyaremko Did you manage to get the Style 796M wheels yet and have them installed? I'm just curious also about the M-sport brake clearance as well. I'm also planning on square setup for winters
One of the websites in Norh America (USD):, otherwise local dealership.
https://www.getbmwparts.com/c-g20-3-series-2018--294
Side note, there could be possibility of some sort of discount from the dealership as prices are MSRP.
      07-23-2019, 08:35 AM   #4
Delta5
47
Drives: 2020 M340i, 2018 X3 30i
ZTK?
Do you have the HP Cooling & Performance package (ZTK)? This matters, as I don't think 18's will fit over the larger ZTK front brakes.
I'm in this same dilemma. I have the same staggered 19" setup, but I have ZTK. Starting to think about winter wheels & tires, and I'd prefer a square 18 setup too. 796M's with winters would be my ideal choice too, but I don't think it'll work.
I'm very curious to hear about what others are doing for winter tires.
      07-23-2019, 12:02 PM   #5
TTG
TTG's Avatar
935
Drives: M340
I just ordered the car with all season non rft 18s and did not check the box for ZTK as it is a useless option for my daily driving purposes.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      07-28-2019, 06:20 PM   #6
tyaremko
Originally Posted by pkancel View Post
I just removed my OEM set of 18s, wheels, tires, TPMS and Center caps to put on the OEM 20s. Here are the specs if you are interested, I will sell you this set for far less than you will pay from a dealer as I dont need these sitting around in my garage. They are All Season, These are the 18x7.5 et 25 all around, wheel is style 780. 225/45-18 Bridgestone Turanza tires, which are Run Flats and only 3,500 miles on them.
Where are you located? Interested
      07-28-2019, 09:26 PM   #7
pkancel
pkancel's Avatar
149
Drives: BMWs
[I also posted them in classifieds section here. I am in So Cal. QUOTE=tyaremko;25079825]Where are you located? Interested[/QUOTE]
Sold
      08-07-2019, 06:47 PM   #8
WXdrivefun
WXdrivefun's Avatar
278
According to the youtube video here:
it seems the 18" Style 796M wheels do fit with the blue Caliper M-Sport Brakes.
See timestamp 0:56s to 1:02
      08-08-2019, 04:57 AM   #9
Delija
VIP
Delija's Avatar
41
Drives: G20 M340i xDrive
Without ZTK (or 33T in Europe), even 17" should fit.
Standard M Sport front rotors are pretty small - only 348 mm. With ZTK - 374 mm.
M Sport on my F30 328i is 370 mm.
Life is not measured by the number of breaths you take but by the moments that take your breath away...
      08-13-2019, 08:21 AM   #10
Delta5
47
FYI, TireRack has updated their 2020 M340i info to include wheel & tire packages, including winter. Their system says various 18's and 19's will fit. But it does NOT currently question whether "sport brakes" are installed, as I've observed on some other BMW models in their system. I wonder if they know about ZTK and whether it matters for 18's?
      08-15-2019, 08:38 AM   #11
Delta5
47
I emailed TireRack regarding ZTK. They responded that it's the same sized brakes as the M550i and that 18's will not fit. YMMV.
      09-05-2019, 11:31 AM   #12
NeverEnough007
43
Drives: 2020 M340i & 1991 Mtechnic E30
There are 3 brake sizes. Standard which comes on 330I msport, the larger msport brakes on the m340i, and the even larger optional ZTK brakes. The middle size does fit into 18" but, not 17".
g20
