05-17-2019, 11:11 PM | #1 |
77
Rep 81
Sport Mode Steering Feels Like Comfort
I'm curious if anyone has experienced what I'm seeing. Over the last week, the Sport Mode steering on my 2017 340i went from feeling very stiff to feeling like Comfort mode steering now.
Is this something that is configurable (i.e. setting Comfort steering when in Sport Mode) that I might have accidentally mucked with? My Sport mode setting is set to include both drivetrain and chassis. Not sure there's any other setting. Perhaps something more serious that needs to be looked at? Thanks. |
05-18-2019, 12:06 AM | #2 |
2589
Rep 2,432
Drives: 2021 M2C
I have not had any issues so far. However, it could be that you don't notice it anymore because your used to it now. For example, I still feel it firm up when I put it in Sport but when driving I don't really notice it.
dbright0377.00 |
05-18-2019, 07:43 AM | #6 |
2966
Rep 6,003
The electric steering in newer Toyota's is better than the old hydraulic steering which was like steering a school bus with a million turns to get to full lock.
05-18-2019, 03:24 PM | #7 | |
77
Rep 81
Thanks for the input everyone! Cheers. |
bimmer4562966.00 |
05-18-2019, 05:17 PM | #8 |
343
Rep 2,118
05-18-2019, 05:30 PM | #9 |
Not stock
474
Rep 614
they should race Honda pilots in ALMS then
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
05-19-2019, 11:34 AM | #11 |
5556
Rep 5,372
You've probably gotten really use to it. Sometimes my M235 feels that way and then I rent a car for a few days during work and then drive my car and think the steering feels a ton heavier and direct.
People can bitch all they want about BMW electric steering, but if you rent a ton of cars, trucks, and SUVs on a regular basis, you'd know the electric steering in the later model BMWs is really quite good.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
MacklinUSOB518.00 |
05-19-2019, 12:15 PM | #12 | |
2966
Rep 6,003
05-19-2019, 12:34 PM | #13 |
24
Rep 6
Drives: BMW F30 335i Xdrive
Actually yes, I had this happen recently too. I definitely didn't just 'get used to it'. It happened randomly in the middle of a spirited drive and took me by surprise. I didn't think much of it and figured it would just fix itself. To my luck, it did. Took a week or so, but eventually, it went back to being stiff when in sport & sport+. It's a little worrisome since I have absolutely no idea how it fixed itself.
dbright0377.00 |
05-19-2019, 07:10 PM | #15 |
10744
Rep 3,690
This happens to me every time I switch between my F82 and the F32.
Sport Plus on the F32 feels like Comfort but I sometimes prefer this steering on some tracks. |
05-19-2019, 07:51 PM | #16 |
518
Rep 891
My comfort steering weight is similar to sport mode of my stock car. Wider tires up front makes a big difference, F80 LCA and TS give much more feel.
I always thought the more assist in the rack the less road feel can transmit. I keep it in comfort. The EPS hate is silly.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
05-19-2019, 11:35 PM | #18 | |
77
Rep 81
05-20-2019, 07:24 AM | #19 | |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
At least sport/sport + gives the f3x steering life. |
05-20-2019, 11:07 AM | #20 |
2589
Rep 2,432
Drives: 2021 M2C
05-20-2019, 11:16 AM | #21 |
1646
Rep 4,877
Depends what you are quantifying as "crap". The E9x had hydraulic assist steering. It was insanely precise, gave you a great road feel, but it felt like you needed gorilla arms at low speed.
The F3x is just "numb". When the wheel is centered, there is this insane dead spot (worse in sport than comfort). Sure, the VSS is nice, it is a lot lighter, but as a "drivers car" the E9x had superior power steering. As a daily driver car, I have no complaints of the F3x EPS, but it makes you more disconnected from the road. That being said, the electric in the F3x saves you a ton in fuel since it only engages as necessary and you aren't spinning the power steering pump all the time. |
05-20-2019, 04:35 PM | #22 | |
2589
Rep 2,432
Drives: 2021 M2C
