05-16-2019, 07:19 PM | #1 |
BimmerPost Supporting Vendor
24179
Rep 190,777
VRSF S55 Top Mount Intercooler Upgrade for 2015 2019 M2C, M3 & M4 F80/F82/F87
VRSF HD Top Mount Intercooler Upgrade for your S55 2015 2019 M2 Competition, M3 & M4 F80/F82/F87 Replace your inefficient factory top mount intercooler with the VRSF upgraded air to water intercooler upgrade kit to get the most out of your S55. We designed this kit to be one of the best performing, direct bolt on intercoolers available for your BMW with special attention to quality and performance while maintaining a reasonable price. Our intercoolers allow for higher HP gains, mainly due to their ability to keep intake temps down while preventing heat soak which is a common problem with the factory intercooler. This results in a more power and increased reliability with reduced chances of pre-detonation & knock. The most important component of any intercooler is the core. The core cools the charged air from the turbo before it enters the engine and the OEM BMW tube and fin intercooler is designed to support low boost levels and air flow. Once boost levels and air flow are increased, the OEM unit is easily overwhelmed and can not keep up with the cooling demands of a tune running more than OEM boost levels. This results in heat soak which will result in a power loss and a higher potential for pre-detonation in the upper RPM range. The OEM intercooler will rise in temperatures up to 105 whereas the VRSF dual pass, high density top mount intercooler will reduce temps down pull which is both harmful for your engine and robs you of power. We remedy this problem with our custom bar and plate core design which utilizes a staggered and offset high density internal and external fin pack. Our proprietary VRSF HD core has been carefully tuned to provide the the best intake temperature reduction while maintaining minimal pressure drop along with our CFD optimized cast end tanks. Every VRSF product includes our lifetime warranty & our No Hassle satisfaction guarantee which includes fitment & defects. Each VRSF intercooler is hand finished and pressure tested to ensure a high quality, leak free experience. Features
Note: Fits both Left Hand Drive & Right Hand Drive Models
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 05-16-2019 at 07:26 PM.. |
05-20-2019, 10:06 AM | #3 |
1231
Rep 845
Can we see some temperature testing done with constant IAT between stock and this VRSF intercooler?
Instagram: @Project_F87
