Brake pedal still feels soft after full ABS system bleed
05-16-2019, 04:05 PM | #1 |
2659
Rep 6,290
UPDATE PROBLEM RESOLVED: My brakes were warped to hell so I decided to change them. Went with Meyle rotors and Textar Disc and WOW that pedal feel is restored to exactly how it was when I picked the car up from the dealer. Guess my Centric mettalic pads and rotors weren't up to par. Maybe I improperly bedded them in to? Happy to finally have my great pedal feel!
Okay so I had this softy feeling pedal for a while now and today I did new brake bleed since I had an issue with my front left bleeder screw. I did the full BMW TIS bleed procedure that is to normal pressure bleed all 4 corners. Then one corner by one, open the valve, run the software so the pump activates, then pump the brake 5 times, close valve and go to the next one. Even after all this my pedal feels kinda soft. At this point I'm thinking it might be the brake pads that are shitty and their bite is not really good and would need an upgrade? My current brake pads are Centric Posi Quiet Metallic. Anyone can chime in... thanks. Last edited by TheMidnightNarwhal; 08-16-2019 at 08:23 PM.. |
05-17-2019, 08:11 AM | #2 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
I went down this rabbit hole last year. Wasted a G note swapping the master cylinder after I was convinced this was the issue. It was not.
Then I had a shop re-bleed ensuring the ABS module was activated. This helped a LITTLE. Then I installed copper caliper bushings hoping the spongy rubber bushings where the issue, this helped a LITTLE too. After all that time and money wasted I decided to live with it. I know when my pads were close to being done the spongy-ness was worse. I don't know if any of this helps your situation but just sharing my experience. |
05-17-2019, 10:15 AM | #3 | |
89
Rep 167
05-17-2019, 02:44 PM | #4 | |
2659
Rep 6,290
Comparing to my mom's new car, her's felt so much firm it's crazy. Thing about brake pads I was thinking maybe the initial bite is the issue but yeah... guess it's just a quirk of this car! |
05-17-2019, 02:45 PM | #5 | |
2659
Rep 6,290
Don't know how worth to try it again. Yours really became better? |
05-17-2019, 02:50 PM | #6 | ||
89
Rep 167
05-17-2019, 02:53 PM | #7 | |
2659
Rep 6,290
Guess I'll decide this week end. |
05-17-2019, 03:16 PM | #8 | ||
89
Rep 167
05-17-2019, 03:18 PM | #9 | |
2659
Rep 6,290
Might give it a go, if I do I'll reply back here eventually. |
05-18-2019, 05:00 AM | #10 |
480
Rep 1,600
Fluid isn't that expensive to compromise. It absorbs moisture when exposed to air.
I have done numerous master cylinder and DSC module swaps, bled as per the repair instructions and never had any issues. Just one round of bleeding through INPA or ISTA/D. Don't pump the pedal rapidly when prompted. Do firm and steady full strokes and use your foot to allow the pedal to return against your foot instead of spring back up. You need to determine if it is a lack of bite or if the pedal is truly spongy. With the engine idling apply firm constant pressure and the pedal should not sink further. Did you machine the discs or fit new discs? Csmoove - Our cars are electronically rear biased. Could that be causing your poor brake performance? What calipers did you fit on the rear? You can change calipers without losing much fluid |
05-19-2019, 11:27 PM | #11 | |
2659
Rep 6,290
I also had a camera set up to see if fluid came out bubble free as per TIS instructions for bleed routine and it did. And yeah you are perfectly right, I'm not experienced enough to know if lack of bute or spongy pedal. So when is is idling, apply a set ammount of pressure and eventually it shouldn't be able to be pressed further? I'm not sure I understand the test. And well, I did change my whole front and rear pads and disc yes when I did brake change back a few months. |
05-21-2019, 10:27 AM | #12 | |
705
Rep 2,605
This is why I was convinced it was the master cylinder. I still get this a little. |
05-22-2019, 12:18 PM | #13 | |
89
Rep 167
05-22-2019, 12:34 PM | #14 | |
2659
Rep 6,290
Hard to remember but I could swear my pedal felt more firm than this when I bought the car last summer at 89k KM. Then at 94k KM I changed rear pads and rotors. Then at 98k KM I changed my front disc and pads and did a full basic brake flush (no ISTA/ABS software) and I remember at how disappointed I was that day, I was going to expect a more firm pedal thanks to bleeding just like my mom's new car (Euro SUV) but not really. And now at 106 00KM I did a second go at bleeding doing the full official BMW way thinking it would make it nicely firm and nada. So maybe in the end it IS my front pads? Do brake disc can alter pedal feel or it would really only be the pads at the limit? I might buy Textar pads and try... IDK... And like I said I tried another member's N55 brake pedal and his felt pretty similar to me. Last edited by TheMidnightNarwhal; 05-22-2019 at 01:56 PM.. |
05-22-2019, 01:54 PM | #15 |
2659
Rep 6,290
Really tempted to try out Textar pads since that was what was on it and since it could be a cause of my pedal feel. They are like double the price of the pads I purchased so I'm leaning 90% towards poor pads... still looking for input tho.
05-22-2019, 02:14 PM | #16 | |
705
Rep 2,605
https://www.e90post.com/forums/showthread.php?t=1421826 |
05-22-2019, 08:40 PM | #17 | |
2659
Rep 6,290
I do see someone else mentions though to stick with OE equipement/Textar... argh really wanna get Textar but it's throwing a random 100$ at it and I don't like throwing random money at issues. And that's without including the rear pads. Man if only I could recall 100% how it felt... |
05-23-2019, 09:56 AM | #18 | |
705
Rep 2,605
05-23-2019, 10:04 AM | #19 | |
705
Rep 2,605
05-23-2019, 07:44 PM | #20 | |
2659
Rep 6,290
One thing I just did just now on my drive I don't know how you can explain it I was driving like 140 and coming to a stop on the off ramp so I brake slowly but firmly and like I released the brake to cruise, then when I went back on it oh my wow the pedal feel felt really firm. Would you have nay idea why? Is it just the heat that is doing that maybe? |
05-26-2019, 06:33 AM | #21 | |
480
Rep 1,600
Is your brake pedal rock hard (hardly any travel) on cold starts? What size tyres are you running front and rear? You mention a drag setup so i imagine the rear would be a non OE size |
05-26-2019, 09:24 PM | #22 | |
2659
Rep 6,290
On startup no pedal feels normal as it is. I don't run anything drag specefic yet but I do think my current street setup is non OEM. Front is 235/35/19 and rears are 265/30/19 I'm really really thinking it's just a lack of bite at this point. |
