05-16-2019, 02:16 AM | #1 |
Rep 2
Transmission Malfunction error message
I have a 2015 BMW F30 328i with 34,118 miles, out of warranty.
The other day, I was driving local, when all of a sudden my right window started rolling down in weird increments. I was not able to roll my window up. At the same time, an error message appeared on my dashboard: "Transmission malfunction". As I quickly pulled over, my car started to lose power, and my steering wheel started to stiffen up. Eventually when I got to the curb, my car lost all power and shut down. I tried to restart the car but not successful on the first few attempts. I waited a few minutes and was able to restart the car. I was around 1.5 miles away from home, so then I decided to drive home. My car shut down again with the same error message once more before I got home, but I was able to again restart my car after few attempts, and made it home safely. The next day, I had a tow truck tow my car to the dealership as I was not comfortable driving my car. The service advisor ran my car's codes, and said there are many issues popping up. He was not able to determine the root cause of this issue. However, he said it doesn't seem to be a mechanical/transmission issue. Seems to be an electronic issue. Since my car is out of warranty, BMW dealership is charging an absurd amount of money. I've attached BMW's repair estimate. Even after all the repair, they cannot guarantee that it'll fix my car's issue. The service advisor said, "First page is what we will have to begin with. If the problem still is not fixed page 2 would be next step." I am thinking this might just be a battery issue. Any thoughts? Thanks in advance. I’ve also attached the error message on my dashboard. |
05-16-2019, 02:31 AM | #2 |
731
Rep 1,045
wow that really sucks, such low mileage with all these issues, definitely dont go through the dealer. Unplugging the battery will not fix anything, that I know for sure. It seems like you need a software reset, I was going to suggest you getting the OBD and bimmercode to reset but I think you need ISTA and hook up for a full factory reset. you have to call around and find a local shop that has BMW's ISTA software and reset the ECU back to factory. That's what I would try first.
Mods: Dinan Tuned, Intake, Catless DP
05-16-2019, 04:27 AM | #3 |
238
Rep 878
Are they really going to charge you approx $340 labor charge to fit a new battery, in my books that’s over 2 hours labour charge to do something that should take 30 mins? 15 mins to fit new battery, 15 mins to code/recode new battery, this should be bread and butter stuff to them that they have done time and time again?
I’d have a word with them and if they don’t want to improve the prices have my car towed elsewhere. |
05-16-2019, 06:54 AM | #4 | |
2966
Rep 6,003
05-16-2019, 07:38 AM | #5 |
Yoda of mods
1675
Rep 3,006
Drives: X5 RWD
Of course they are.
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
05-16-2019, 07:42 AM | #6 |
221
Rep 529
What's being suggested to the OP is to load up the car again on a wrecker and go shop Indies.
Is this really the time to be doing that? My step 1 would be to buy a new battery at a place like Autozone and install it myself while the car is sitting, parked in the BMW stealership parking lot. The Duralast H8-AGM battery sold at Autozone fits your needs and costs about $200. That compares favorably to the $663 your stealer wants to charge you. Worry about registering the battery later, first see if a fresh battery solves your problem. podman Last edited by Mr Podman; 05-16-2019 at 07:49 AM.. |
05-16-2019, 09:53 AM | #8 |
731
Rep 1,045
I don't know why people are saying its a battery issue, first the car would tell you if the battery is low, second, i know the dealer is useless, but i still think they're capable of telling you if your battery is low, also a volt meter check takes 30 seconds to confirm battery voltage yourself.
05-15-2020, 09:26 PM | #10 |
Rep 1
I have a similar problem with mi BMW 328i 2014, I have a similar problem with my car, the vehicle works perfectly, it drives without problems but after a moment driving when I turn it off and turn it on again to use it gives me a code of `` TRANMISSION MALFUNCTION '' and it goes into safe mode, so it does not allow me to put it in D, after a few minutes it is safely removed by itself and I can already handle it again, sometimes it takes hours to do it, I have researched a lot on the internet but I have not found a solution, in fact I changed the battery because the one I had was no longer working, I even had it programmed for him but the failure persists.
02-16-2023, 08:21 PM | #12 |
Rep 5
maybe ground strap broke. i didnt lose power while driving but got a transmission malfunction trying to start my car. It wouldnt start - no odd noises or odors so had to get towed to dealer. Turns out the ground strap rusted through and broke. New ground strap and it works fine now.
