05-14-2019, 09:23 PM | #1 |
Rep 2
Yes..I CAN'T get my airbag out!
2015 328xi
Alas....I have tried what seems like hundreds of times to remove my airbag and cannot locate those damn clips. My fingers are raw and I have torn my steering wheel to shreds. The photo attached shows my view of looking at the right side of the steering wheel. Where are those clips??? Thanks for any and all help! Last edited by knowl; 05-14-2019 at 09:33 PM.. Reason: Add photo |
05-14-2019, 10:55 PM | #2 |
2589
Rep 2,432
Drives: 2021 M2C
Why are you removing your airbag??
05-14-2019, 11:25 PM | #3 |
dad bod
387
Rep 382
Holy hell OP! Sorry this is causing you such a headache. Not sure the clips are visible from the angle of the photo you posted.
Not sure if this works with the m-sport wheel but might be worth a try:
'15 F30 Estoril Blue 335i xDrive | 8HP | Stock Turbo | 420 awhp / 451 awtq | 11.85 @ 115 mph
E30 JordanTuned on BM3 | XDI-60 HPFP | Fuel-It! lines + sensor | VRSF FBO | GFB DV+ | XHP | Vörsteiner VFF-107s | Dinan Springs |
05-15-2019, 04:08 AM | #4 |
1999
Rep 2,499
There are two small holes under your steering wheel. They are somewhat covered by the soft plastic. You need to insert a screwdriver or some other tool (I used a T25 driver) to push a clip over. This is EXTREMELY difficult if you have never done it before.
An easier method might be to remove the steering column shrouds. Then just turn the steering wheel and at a certain angle, you will expose the two metal clips behind the wheel. Then you can take a flathead screwdriver and just pop the clips off from behind the wheel. This is not as easy as it sounds, but it will be easier than the first option above. Also, the airbag will be a little stuck so you also need to actively pull while undoing those clips. |
05-15-2019, 06:34 AM | #5 | |
839
Rep 440
Drives: 2013 335i xDrive
I'm not completely useless, I can be used as a bad example.
05-15-2019, 07:07 AM | #6 |
8245
Rep 16,088
I tried the video method, found that I couldn't get the clip to open and stay open. I ended up using the video method to see the clip while inserting a T20 torx bit driver through the slits in the wheel, which worked. Using a torx bit driver is critical too, a regular screwdriver isn't the right shape.
05-15-2019, 09:28 AM | #7 |
769
Rep 1,755
I feel this guy did a great job describing the process. I watched the video once and figured it out. Took about 2 hours total including swapping over the multi function buttons and paddle shifters over to my new steering wheel.
05-18-2019, 08:34 AM | #9 |
Rep 2
05-18-2019, 11:33 AM | #11 |
Respect My Authoritah
368
Rep 873
It's all about the tool. Some snowblowers or weed whackers come with a tool to change the spark plug that has a Philips driver on it too. The driver was the perfect size, but nothing else in my toolbox worked.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
05-25-2019, 01:54 PM | #12 |
dad bod
387
Rep 382
Agreed. I got lucky and found out that a 3mm electrical coiling rod was the perfect fit. Having a flat top really helps.
05-25-2019, 04:43 PM | #13 |
2JZ-GTE
3045
Rep 3,996
Insert crude comment here
05-25-2019, 05:05 PM | #14 |
BMW CCA Member
488
Rep 808
Syc01.00 redEYEjedi768.50 |
05-25-2019, 07:23 PM | #15 |
Rep 12
I feel your pain, i had to get the steering wheel off for a dashboard change. After prodding many things in there a Philips flat head done the trick. flashing a light into the hole helped locate it. You'll feel resistance just as the tip of the driver goes slightly into the hole.
05-27-2019, 08:54 PM | #19 |
989
Rep 2,200
Not familiar with this type of screwdriver (I'm in the US) - do you have a picture?
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
05-28-2019, 05:58 PM | #20 | |
769
Rep 1,755
05-28-2019, 06:36 PM | #21 |
989
Rep 2,200
I didn't know - that's why I asked.
05-28-2019, 11:05 PM | #22 |
2589
Rep 2,432
Drives: 2021 M2C
Tags |
airbag |
