Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > DOT 4 vs DOT 4 LV (Low Viscosity)
      05-14-2019, 08:10 AM   #1
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2659
Drives: 11' 335is DCT
So BMW TIS and RealOEM call for DOT 4 LV but my dealer don't have it and say even their own techs only use the regular DOT 4.
Has most of you just used regular DOT 4 and have been good? The way it's worded in TIS seems like they really want you to use LV fluid.
      05-14-2019, 04:32 PM   #2
Tambohamilton
3058
Drives: E91 330d
Ages ago, somewhere I now can't find, I read that LV has a way higher boiling point than standard. Also lower viscosity for SC, ABS etc to work a bit easier... I'd go for LV every time anyhow; no sense skimping on brake stuff, I think.
      05-14-2019, 06:40 PM   #3
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
Do you have NAPA auto parts stores?
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
      05-14-2019, 08:33 PM   #4
TheMidnightNarwhal
2659
Ok well update, the original fluid dealer sold me does say Low Viscocity on it. But the part number they told me it was didn't match to LV when I searched.
T
he dealer guys said by email they only use DOT 4 my god do they have no idea what they talk about sometimes.
All good now guys!
      05-15-2019, 08:44 AM   #5
drawz
drawz's Avatar
78
Drives: 06 330xi 6MT, 08 535xiT 6MT
Boiling point is not significantly different. If anything, it's slightly lower when "wet" for the LV. Officially our cars use LV, which is what BMW sells, but a lot of people use regular DOT 4. Here is a good reference:
https://blog.fcpeuro.com/brake-fluid-academy
      05-15-2019, 08:54 AM   #6
TheMidnightNarwhal
2659
Yeah I had seen that and it's kinda odd though.
They don't recommend doing track with LV but then BMW says LV only or it can fuck up ABS/DSC systems.
ABS/DSC system isn't cheap so it's why I'm making sure I only use LV but hope I can still do a few track/auto cross fun.
If not people who used regular DOT 4 all around have they had issues, I guess not either...
I don't do serious tracking but I do go at some small tracks and drags for fun.
      05-15-2019, 01:32 PM   #7
drawz
drawz's Avatar
78
Don't over-think it. Either is fine in our cars. It won't break your ABS/DSC system. If you want to be cautious, just get the LV as specified by BMW. For track, the non-LV fluids seem to have slightly higher boiling points, especially when wet, but those also typically are/should be changed more often.
      05-18-2019, 05:05 AM   #8
juld0zer
Australia
480
Drives: Prev 135i 7DCT, Now 130i 6sp
In addition to this, the low viscosity fluids are strongly recommended largely for comfort reasons (less perceptible pulsations) and for optimum DSC modulation (valves are calibrated for the low viscosity fluids). There was an article which showed LV fluids allowed for more finer intervention.
BMW dealers should only be using LV.
Lots of OEMs don't specify LV fluids despite being equipped with DSC. Toyota and Mazda still specify DOT 3 fluids in some of their cars
renizer12.00
      12-10-2020, 07:32 AM   #9
Doctor MATT
Drives: BMW 335i E92
DOT 4 Class 6 ! LV - предназначена для авто оснащенных системой курсовой устойчивости ABS, ESP.
Она имеет лучшую текучесть при низких температурах (кинематическая вязкость при 40С 700 mm2/s).
У DOT 4 - при 40С 1400mm2/s.
