05-13-2019, 03:37 PM | #1 |
124
Rep 268
Water from exhaust - lots of it 340i
This caught me by surprise last night.
Earlier in the day I had done a 70 mile ride up the motorway just taking it easy. On the way home I gave it some of the right foot so was averaging 70/80 and on occasion some more. Needless to say it was a continuous journey of about an hour or so so everything up to temp. When I got home I noticed a trail of water up the road and onto the drive. On closer inspection the rear left was dripping continuously, literally drip drip drip. It didn't smell of anything. I know exhausts drip but I've never seen anything like this. I have no warning lights. Prior to the trip the car was idling slightly rough, and you could feel it coming through the floor. Its only on 4k miles and I've owned it from new . Anyone had similar in relation to manic dripping from the exhaust bearing in mind after an hour or spirited driving I would have thought any moisture would have gone from the system. |
05-13-2019, 06:16 PM | #2 |
Just Copacetic!
177
Rep 616
Are you certain it’s dripping from the exhaust? I’ve had water condensation drips onto the driveway when the A/C has been running for a bit, esp during the summer months. There’ll be a decent puddle after stopping/parking but it will be clear and definitely water condensation from the A/C.
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite '19 230i MSptPkg AlpWhite |
05-13-2019, 06:44 PM | #3 | |
731
Rep 1,045
Mods: Dinan Tuned, Intake, Catless DP
05-13-2019, 06:54 PM | #4 |
1999
Rep 2,499
As long as it's just water and not coolant or gasoline, you're fine. Depending on how you drive, it's possible for the byproducts of combustion to pool in your exhaust and then suddenly drip out if your car is at the right incline or when you accelerate.
H20 (water) is a natural byproduct of combustion. Completely normal. Unless you notice any other issues or if the liquid smells like something else, i wouldn't worry. |
05-13-2019, 06:56 PM | #5 |
806
Rep 1,906
Have you checked the level of coolant in the expansion tank?
Head gasket failure often shows as white (steam) exhaust from tailpipe- this doesn't sound like that, very unusual, hmm.... |
05-13-2019, 06:58 PM | #6 |
731
Rep 1,045
it's a new car with 4k on it, i dont think it's a head gasket lol, I know bmw isn't the most reliable but come on. I still think it's catalytic related, maybe it's being broken in.
05-13-2019, 08:32 PM | #8 |
8245
Rep 16,089
One of the products of the combustion of hydrocarbon fuels is water, the result of the hydrogen combining with oxygen to create H2O. Perfectly normal.
05-14-2019, 07:38 AM | #11 |
8245
Rep 16,089
A CAT increases the amount of water produced by combining unburned hydrocarbons with oxygen, but the main source of water is the combustion in the engine. All hydrocarbon combustion produces water, including the oil or gas furnace in your house. You're not aware of it because it goes up the flue as water vapor. With a car some of that vapor cools enough by the time it reaches the tail pipe to condense to liquid water.
05-14-2019, 09:49 AM | #12 | |
124
Rep 268
We just thought it was a hell of a lot but perhaps circumstances dictated its sudden release ie the slope. No smell to the water. No worries then cheers. |
05-14-2019, 01:45 PM | #13 |
128
Rep 262
My new 340 produces tons of water also. Probably normal...
vinzcast21161.00 |
05-14-2019, 02:09 PM | #14 |
2589
Rep 2,432
Drives: 2021 M2C
05-14-2019, 02:15 PM | #15 |
5556
Rep 5,372
The cat converter makes water as byproduct. Water temporarily gets trapped in the muffler can. Water leaks out. Science.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
05-15-2019, 11:12 AM | #16 |
420
Rep 842
I find it odd that after an hour of driving the exhaust heat would not have evaporated the water. You see water/mist in the morning when the car first starts, but again the exhaust heat should take care of it after warming up.
I’d take it in just to be safe. |
05-15-2019, 11:32 AM | #17 | |
197
Rep 417
She is not happy with you On a serious note, that is normal as well. Climate makes a difference and the H2O can definitely evaporate from the high temperature within the exhaust system. |
05-15-2019, 12:05 PM | #18 | |
BMW CCA 69606
86
Rep 227
The test is to check for dropping coolant level. Hopefully car has a low coolant level sensor. Any chance you've got a trunk/boot full of water and it's leaking out? |
