05-12-2019, 11:41 AM | #1 |
892
Rep 1,075
Suspension debate - adaptive or not?
BMW’s new “lift-related” dampers. This new suspension setup isn’t adaptive and it has no alternative modes. It’s just a passive suspension setup that’s be set up properly. And you know what? It works brilliantly. During my time with it, I was so extremely pleased with how it rode, handled bumps and handled corners. In every situation, it felt perfect. Sure, it was a little on the firm side but never so much so that it was uncomfortable. Instead, it was supple enough, planted and confidence inspiring.
Of course, to do so, you have to make a bit of a sacrifice in one area. In the case of the 3 Series, its new suspension trades a bit of comfort for better handling and dynamics. And it’s well worth it because it’s still comfortable enough for everyday driving and actually has a suppleness that allows you to feel bumps but rounds them out. And because it’s consistent, with no changing modes, you can better learn how it responds and drive accordingly. I wish BMW would do this for more of its cars; just offer a single, non-adaptive suspension setup that works the right way right out of the box. Just like M2 |
05-12-2019, 01:17 PM | #2 | |
6659
Rep 15,858
We are getting comment in some of the UK press that the M-sport passive suspension is not best suited to comfort on UK roads. Even suggesting if you value comfort, delete M-sport suspension and run the standard setup. Have you tried the G20 adaptive, to make any comparisons? IMO, a decent adaptive setup has its place in any model line-up, gives the widest working envelope and scope for less compromise. |
Ilyam5891.50 |
05-12-2019, 01:40 PM | #3 |
380
Rep 2,290
I had adaptive on my past two F30 3 series leases, but didn't order it on my G20.
My reasoning was because adaptive has been historically packaged with VSS or other items I felt I needed, and because the non-adaptive suspension (M sport or not) on the 3 series was trash in my opinion. You also couldn't get M sport suspension on an xDrive unless you opted for adaptive, so I think that forced a lot of people to adaptive. With the base and M sport suspension being improved on the G20 vs. F30, and xDrive models being able to have M sport without requiring adaptive, I personally feel the value proposition of adaptive is a lot less on the G20. I always use the sport mode in adaptive, and didn't notice enough of a difference between adaptive M sport vs. M sport on the G20, so the $700 wasn't worth it to me. I suppose if you can discern the difference between non-adaptive M sport and adaptive M sport, or truly want to be able to switch suspension between sport and comfort modes, adaptive may be right for you. |
05-12-2019, 01:55 PM | #4 | |
576
Rep 584
05-12-2019, 01:57 PM | #5 | |
1385
Rep 1,102
///M3 2024 G80 Competition - Starting Lineup
///M4 2019 F82 Competition , 2019 G30 540i , 2008 E92 335i - Retired |
05-12-2019, 04:07 PM | #6 | |
380
Rep 2,290
05-12-2019, 04:13 PM | #7 | |
892
Rep 1,075
Idea was to see what Germans engineered for this car since so much went into handling development and new “lift-related” dampers. I agree it is not the softest. slow driving around beat up Boston roads is bumpy, but not too much. On adaptive i could not find a happy medium. Felt like regular handled turns better. The whole debate on M forums was - which suspension gives you more performance benefits. No one argues that adaptive gives more comfort,. |
Dpfghela11.00 |
05-12-2019, 04:30 PM | #8 | |
6659
Rep 15,858
The whole concept of adaptive is, in words of one of BMW's guys, …"as stiff as necessary, but as comfortable as possible". Going to feel different, even if there are similar limits. Not exactly the same brief as a performance biased passive system. Some of us like the ability to back off a notch for poor road use, adaptive gives that choice. |
05-12-2019, 04:53 PM | #9 |
2006 TIME Person Of The Year
9720
Rep 6,445
Personally I really like the adaptive damper system in my F30; especially after reprogramming them with Dinan Shockware. I'd opt for them again in the G20.
05-12-2019, 08:15 PM | #10 |
24
Rep 49
I test drove the m-sport once. I was pretty much decided on getting m sport. I asked the CA to take me to some windy roads ( there are some in the area), but he could not not find them and instead we ended up primarily on pretty bumpy roads looking for the smooth windy roads. In any event, the ride was very jarring, and based on that I went for the sport line. I even did another test drive of the sportline where I just sought bumpy roads and it handled then fine.
I did see Top Gear's (BBC's) review and they noted the ride as harsh and that was the only negative comment that had about the car. Glad that BMW was very fastidious about suspension though as hopefully they'll come back and be as meticulous with the steering. |
05-13-2019, 03:02 AM | #11 |
Rep 5
Just offering my driving experience of little over a wk of driving so far, I think the adaptive mode drives like comfort in lower speed and feels firmer and more 'road feel' upon higher speed, but not as 'rough' feeling over the bumpy roads as in sport mode, just as the name adaptive suggests it should do perhaps. I'm not technical at all and its just based on my personal driving style. I have the M sport suspension with adaptive setup. And I spent time driving on adaptive mode more than sport mode.
Also, can someone point out if it's normal that I can change settings of the sport mode(though only either sport or comfort in 3 different areas and not really much to customize), but no customizable settings for adaptive mode? |
05-13-2019, 03:18 AM | #12 | |
Rep 10
I think the quote from the BMW guy precedes G20. |
05-13-2019, 03:36 AM | #13 | ||
6659
Rep 15,858
05-13-2019, 06:15 AM | #14 |
World's Foremost Authority
1181
Rep 4,535
Drives: M4 Cab - Cayenne GTS - Jag XK
Location: Upper East Side Manhattan - Boca Raton FL - Lime Rock CT
The adaptive dampers are not simply adjustable they are adaptive and are constantly adjusting to road conditions regardless of what mode they are in. Because of this adaptive quality they will never emulate standard shocks although they may feel similar.
Drivers Club at Lime Rock - International Motorsports Research Center - Society of Automotive Historians - Madison Avenue Sports Car Driving and Chowder Society (0nly a VP) - BMWCCA - Porsche Club of America - M Gruppe - Polish Race Drivers of America (PDRA) - Glen Club (Watkins Glen International) - Jaguar Club of Southern New England |
Sedan_Clan24979.00 |
05-13-2019, 11:04 AM | #15 |
28
Rep 135
I live in the Baltimore/DC metro corridor and, given our supremely crappy roads, am absolutely getting the adaptive setup. There are some great driving roads that won't knock your fillings out in western Maryland/WV and for those glorious occasions, Sport or Sport+ will be welcomed. But for daily driving duties? My kidneys will take "comfort" please and all the pothole absorption capabilities possible.
05-13-2019, 04:40 PM | #16 | |
6659
Rep 15,858
No experience of the G20 models, but have you tried different individual settings for Comfort and Sport modes, to see if this influences how Adaptive mode interprets them? |
05-13-2019, 07:41 PM | #17 | |
380
Rep 2,290
During my test drive, the G20 M340 M sport suspension without adaptive felt more comfortable than my F30 328 with adaptive (while in sport mode). |
05-13-2019, 08:21 PM | #18 |
2589
Rep 2,432
Drives: 2021 M2C
I'll take my non-adaptive suspension, thanks.
05-13-2019, 09:24 PM | #19 |
1181
Rep 4,535
I think suspension choice will be determined by the environment the car is driven in. The sport suspension and RFT tires on my 2007 335i made the car for all practical purposes undrivable on New York City's pot hole infested roads. I was constantly bending rims and damaging tires. My 750Lix and my 2015 and 2018 M4s had adaptive suspensions as does my Jaguar Convertible and my Porsche Cayenne GTS. The adjustable suspension gives me a great balance between the horrible road of NYC and the relatively smooth roads near my home in Lime Rock CT.
The job of a suspension is to keep the tires in contact with the road surface and an overly stiff suspension will bounce the tires around and cause the contact patches (they are called contact patches for a reason) to lose contact with the surface of the road. An overly stiff suspension may be fine on a race track but even a notoriously bumpy track like Sebring is a lot smoother than many public roads. I generally keep my suspension set in comfort mode. I see no reason for an overly stiff suspension in a daily driver.
NordicBob2.50 |
05-14-2019, 07:43 AM | #20 |
82
Rep 248
Do you think either Sport or Sport Plus with the adaptive suspension will be firmer than the M340i standard m-sport suspension?
The car I test drove had the standard suspension, but to be honest I would appreciate a bit more roll stiffness than that car had. |
05-14-2019, 08:06 AM | #21 |
380
Rep 2,290
I would say more dynamic comfort, not stiffer suspension.
05-14-2019, 04:10 PM | #22 | |
28
Rep 135
