05-12-2019, 03:02 AM | #1 |
451
Rep 469
Does start/stop cause rod bearing failure?
I myself have had the rod bearing failure and needed a new engine and I have spoken to other who had the same issue. After the last chat to a guy with the rod failure problem in a N54 I searched for more information and found that BMW started to make an “IROX coating” in N63 and B58 engines and BMW states the following:
Look for the full text in the technical training docs: https://f30.bimmerpost.com/forums/at...0&d=1441950445 The rod bearings used in N54/N55 have been used since the time before the start/stop-mechanism but apparently the start/stop causes excessive wear. Frequent oil changes apparently does not make that much of a difference since it is the lack of lubrication during the stop that is the problem. Luckily I turn of the start/stop quite often but I am now going to remove it by coding.
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
05-12-2019, 08:45 AM | #3 | |
1613
Rep 3,952
05-12-2019, 02:13 PM | #4 |
dad bod
389
Rep 382
I too have mine coded off but this IROX coating business is interesting to me. From what I've read the N55 (and BMW motors in general) have pretty tight rod bearing clearances from factory. Most of the rod bearing failure cases I've read about there's no mention at all of the start/stop function playing any role, but IMO there's no point risking it.
'15 F30 Estoril Blue 335i xDrive | 8HP | Stock Turbo | 420 awhp / 451 awtq | 11.85 @ 115 mph
E30 JordanTuned on BM3 | XDI-60 HPFP | Fuel-It! lines + sensor | VRSF FBO | GFB DV+ | XHP | Vörsteiner VFF-107s | Dinan Springs |
05-12-2019, 06:58 PM | #5 |
Yoda of mods
1676
Rep 3,006
Drives: X5 RWD
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
