Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Front control arm bushings
      05-08-2019, 11:09 PM   #1
Crookedstang
16
Drives: 2009 335i
Been doing a lot of reading on here I need to replace my front control arm bushings in your opinion. Is it worth upgrading to the M control arms ? From what I read seems some people were having issues with alignment after the upgrade. Is there anything I'd need to tell the shop after I do the upgrade ?
Thanks for your time
      05-09-2019, 04:58 AM   #2
zstreet86
116
Drives: 2011 E91 328i, 2008 e90 M3
Worth it. I have them installed. No issues with alignment.
      05-09-2019, 07:54 AM   #3
Wolf 335
Wolf 335's Avatar
2341
Drives: 2007 E92 335i
If you are referring to the curved arm (aka thrust arm), there is no dimensional difference between standard vs m. Only difference is the bushing, hydro bushing vs full rubber. I recently had m ones put on. Road feedback is slightly increased but you get used to it. Alignment should not be affected.
If you are changing the shorter straight control arm I believe that's the one that has a different length (standard vs m) and it would affect your alignment.
      05-09-2019, 07:59 AM   #4
Crookedstang
16
Drives: 2009 335i
Looking at changing both thrust and control arm while I'm in there. I know I'll need an alignment I'm just curious if the shop will have an issue Aligning the car
      05-09-2019, 10:32 AM   #5
BSM n54iS
BSM n54iS's Avatar
2685
Drives: '11 335is | '16 Macan Turbo
Not if they know what they are doing
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete
      05-09-2019, 04:06 PM   #6
000ooo000
17
Drives: 2011 e92 335xi
You can also just put new bushings in your current control arms. Look at strongflex or powerflex. These will be better than m.
      05-09-2019, 07:06 PM   #7
Crookedstang
16
Drives: 2009 335i
Would you recommend changing the control arms as well?
