05-08-2019, 07:38 PM | #1 |
Rep 10
Decision between 2015 versus 2016 328i Xdrive
Hi,
Currently own a 2006 325i and looking to upgrade. I have been looking at 2015 and 2016 certified pre-owned 328i Xdrives, mostly 2015s. I've seen a few 2016s with about 30,000 miles roughly priced the same as 2015s with under 20,000 miles. The 2016s, however, that I have seen in that price range (under $25K) generally don't have many extras and are close to base models. Question: Would you go with the newer model, even if the mileage is a bit higher and the vehicle has fewer extras? Or is a 2015 just as good? Anyone have experience driving both? Thanks in advance for your thoughts! |
05-09-2019, 11:59 PM | #2 |
516
Rep 1,452
Keep in mind there may be less warranty on the 2015. I like having the options. Make sure the features you want work the way you want. Under your scenario,I’d go with the 15.
05-10-2019, 07:21 AM | #3 |
63
Rep 109
The 2016 would come with the n26 vs the n20 in the 2015, not sure if that matters to you at all. I know the n20's had an issue with the time chain, not sure if that was all n20s or just earlier ones. Other than warranty, there shouldnt be too much difference between them. The 2015 will most likely have its warranty expiring this year. I was in the same boat and just bought a '15 328 (gt though) and liked the options better on the car i chose vs ones i was comparing in the 2016 for a similar price.
05-10-2019, 07:28 AM | #5 | |
2413
Rep 4,451
Drives: '23 X1 28i xDrive
ndx6spd79.00 |
05-10-2019, 12:13 PM | #6 |
Rep 10
Thanks guys for your thoughts!
As I mentioned, the 2016 is fairly limited as far as features are concerned and has higher mileage of around 28,000, as I recall. However, its original warranty has another 15 months. The 2015 has more features, lower mileage with about 12 months left on the original warranty. The difference in price is about $1000 more for the 2016. |
05-10-2019, 01:23 PM | #7 |
Rep 16
Literally me in March of this year. I decided to go with the 2015, the features + low mileage sold me easily. Also, I went on the last day of the month a couple hours before they closed and they chopped off 2k before I even made my initial offer, I believe they're more willing to negotiate on older models to get rid of them faster.
05-10-2019, 01:23 PM | #8 |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
What is the build date on the 2015? Make sure it’s at least 01/15 and later as BMW changed the timing chain.
05-10-2019, 01:36 PM | #9 |
204
Rep 499
2016 will have the timing chain revision, for sure. The 2015 might have the timing chain revision, depending on when the engine was built, but it's only speculation when BMW started using the new part in production (the new part number came out in Jan of 2015, I believe). I wouldn't even consider risking it, with a 2015 though -- no way in hell.
Plus, 2016 is the first year of the LCI -- so it has the handful of other tweaks and revisions. 2017 330i would be the way to go, if you can wait and save up a bit -- as it has the improved crash structure, as well -- so that your legs don't get pulverized in a font small-offset crash. |
05-10-2019, 03:03 PM | #10 |
Rep 10
Thanks for the timing chain information.
Here's the two cars I'm considering. The price difference is actually around $2400, although I'm now realizing that the 2016 is not CPO. 2016: https://www.bmwoffreehold.com/used/B...fd7c1d6fc1.htm 2015: https://www.flemingtonbmw.com/used-F...3B5C52FF960970 There are a few other 2015s in this range/mileage available at other local dealerships. |
05-10-2019, 03:29 PM | #11 |
8245
Rep 16,088
N20 and N26 are the same engine save for their emissions controls. The timing chain is the same in both.
OP, I'd take advantage of the year model depreciation savings with the 2015, getting a better equipped car for less money. |
05-10-2019, 04:32 PM | #12 |
204
Rep 499
The 2015, sadly, does not have the sport seats -- so I would not recommend it. The sport seats are one of the best things the 3 series has going for it. Most 2016+ model years have the sport seats, by the way -- unless they were specifically "deleted" due to the inclusion of the luxury package.
