05-07-2019, 05:29 PM | #1 |
Rep 16
Brakes are Sqeaking, what do I need to do?
I recently purchased a 2015 BMW 328xi (F30) and the brakes are squeaky when going slow. I'm not sure if I need to replace both the rotors and the brake pads or if I just need the brake pads.
I have attached some images below that will hopefully help you understanding my situation. If you need better pictures please message me or reply to this thread and I can supply some more specific ones too. My vehicle has 43,000 miles btw so I'm assuming these are still the original brakes. View post on imgur.com View post on imgur.com View post on imgur.com View post on imgur.com The car also has the upgraded "M-Sport" calibers. not sure if that makes a difference tho on what brake pads I would need to put in. Thank you! |
05-07-2019, 05:40 PM | #2 |
839
Rep 440
Drives: 2013 335i xDrive
I see new pads in your future. Those are toast.
I'm not completely useless, I can be used as a bad example.
05-07-2019, 05:52 PM | #3 |
5886
Rep 10,256
If the rotors are glazed, replacing rotors and brakes at the same time is recommended.
Rotors are not expensive. Visit https://www.turnermotorsport.com to research rotor and brake pads options. |
05-07-2019, 05:59 PM | #6 | |
Rep 16
05-07-2019, 06:00 PM | #7 |
Rep 16
Do you think it would be smartest for me to just replace the pads for now then once the rotors ware then replace those later on? Or does it also look like the rotors are toast. I'm not too knowledgeable on this topic haha.
Thank you very much for your reply |
05-07-2019, 06:03 PM | #8 |
5886
Rep 10,256
For daily driving, regular rotors (no drilled holes, no slots, no dimples) are just fine. No need to spend extra money.
If you do want to consider better brakes, M Performance (OEM BMW aftermarket brakes) brake kit can be installed but at a higher price. |
05-07-2019, 06:12 PM | #9 |
Rep 16
I was always curious on what the drilled holes and whatnot meant so thank you for that! And yeah I just use it for regular daily driving nothing too special.
05-07-2019, 06:21 PM | #10 | |
839
Rep 440
Your rotors may be ok, the only way to know for sure is to measure the thickness and the runout and the depth of the scores. If there is a doubt, throw them away and get new ones. They are fairly cheap and it's not worth the gamble.
05-07-2019, 06:25 PM | #11 | |
Rep 16
05-07-2019, 06:26 PM | #12 | |
5886
Rep 10,256
Excellent article to read with lots of technical details: https://www.good-guys.com/hotnews/te...-brake-rotors/ In short - for daily driving, drilled rotors do not offer measurable benefits. |
05-07-2019, 10:23 PM | #15 |
Rep 16
05-08-2019, 08:01 AM | #17 |
221
Rep 529
I just DIY'd my front brakes.
Pelican Parts was my source for parts. Has been for years. I've got rear brakes being shipped and expect to install them this weekend. Rotors cost like $55 - $60 That's why I always replace them and never let some toothless idiot turn them. Don't forget to learn where to put BMW brake spooge (quieter) on the calipers - not on the brake pads themselves. There is a right answer. podman |
05-08-2019, 08:21 AM | #18 |
Rep 2
I have a 2014 335i M-Sport, with the M-Performance breaks. Mine squeak too before they warm up. Especially if its cold out. I spoke to BMW about it and they couldn't find anything wrong with the pads or rotors.
05-08-2019, 08:43 AM | #19 |
8245
Rep 16,088
The pads are greased wherever they make metal to metal contact with the calipers or pad carriers, otherwise they can squeak. Brake grease is high temperature, so it won't thin and spread to the pad or rotor surfaces. Obviously you don't want to glob it on, a thin coating will do.
05-08-2019, 09:46 AM | #20 |
Not stock
474
Rep 614
Did you buy it CPO or just second hand? If CPO and you "just" bought it - those pads should have been replaced at sale. At 43k miles it's probably safe to assume you need pads and rotors.
Get some rotors that are plated or coated to avoid the rust
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
05-08-2019, 10:59 AM | #21 | |
1599
Rep 3,748
I live in socal, found a few shop willing to turn my brake rotors, they asking $20 each. CHANGE THOSE ROTORS |
