05-04-2019, 12:52 AM | #1 |
17
Rep 67
Returned to find one headlight on
I parallel parked my car on the street (using the auto park feature) and left it for 3 hours. It was daylight when I walked away from that car. The parking sequence had ended and I even took over manually to reverse a bit to get off a speed bump that stretched across the road. The turn signal stalk was centered (no signal on).
When I returned, it was dark out. I found the driver’s side headlight still on. I imagine it has been on the whole time. Any thoughts as to why this happened?
-lights
2019 BMW x5 40i . premium tier . offroad package . integral active steering . parking assistance package . remote start . trailer hitch . heated seats/wheel/armrests . trailer hitch . 20" wheels . arctic gray Last edited by lights; 05-04-2019 at 02:21 AM.. |
05-04-2019, 03:19 AM | #2 |
210
Rep 323
Drives: BMW X5 G05 30d/BMW M5 F90 Comp
You must have bumped this button before getting out. It turns on the left-side lights.
I had a relative bump the lights on when he was checking out our car, and we had to put them back onto auto. Someone at BMW thought that putting buttons at knee-level was a good idea... |
05-04-2019, 05:25 AM | #3 |
1699
Rep 2,609
WTF?! Buttons that turn on individual headlights? Headlights buttons by knees? Headlights with no off timeouts in 2019? WTF?!
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
05-04-2019, 05:58 AM | #4 | |
210
Rep 323
It won't time out, if it is designed to stay on. |
05-04-2019, 06:19 AM | #5 | ||
1699
Rep 2,609
05-04-2019, 07:28 AM | #6 |
1699
Rep 2,609
Ok, this launched me full on into research of pretty much the most obscure car feature ever. I've been driving for 35 years as of this year and this is the first I've even approximated hearing about this.
Here is a start: https://jalopnik.com/youre-using-you...ong-1822884831 And it turns out that my 14 y/o E46M3 (that is being traded in this week since the X5 has arrived at the dealer, both a :-) and a big :-(( ) has this feature — just leave your left or right blinker on (all the way up push or all the way down push) and only one side parking lights (not headlights or DRLs or fog lights) stay on (and drain the battery for no reason). The obscurity is amazing.
05-04-2019, 10:26 AM | #7 |
17
Rep 67
Thanks guys!! Thankfully, it didn’t repeat itself after driving off and parking in a parking lot or later my garage later last night. So I guess the feature at least resets itself after a drive cycle!!
05-04-2019, 12:37 PM | #8 |
1699
Rep 2,609
Hopefully when coding ramps up, there will be a way to turn off or remap those buttons to something less dangerous and/or much much much more useful.
11-11-2021, 05:43 PM | #9 |
Rep 15
helped me out with my X7
This "feature" is apparently still alive and well in the X7. Couldn't figure out why a single headlight would remain on. A simple google search led me here and, voila. Problem solved.
11-11-2021, 09:25 PM | #10 |
3161
Rep 6,803
Some of this changed with a fairly recent OTA s/w update as the rules in Germany changed. But, this function has been in German vehicles for decades...so, it's not something new. Generally, it doesn't turn the lamps on at full voltage, and in older ones, they had specific, low wattage bulbs specifically for this purpose. The logic then also was setup so it could detect if the 'normal' bulb was out, and substitute the one normally used during this parking situation until you could change the bad bulb out. Lighting and some of the really narrow, sometimes curvy roads in Europe may mean reflectors may not be all that useful.
11-12-2021, 05:16 AM | #11 |
Rep 23
Had a BMW 530i in 2002 (still the best car I ever had) and leaving the turn signal stalk in either position would activate one side of parking lights. At the time I felt very “European” living in the US when I activated it. Now I just feel silly. Aging is no fun.
timmahh483.00 |
11-12-2021, 10:44 AM | #12 | |
ghey
483
Rep 2,041
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
11-12-2021, 10:58 AM | #13 |
ghey
483
Rep 2,041
It will never repeat itself, just as the headlights should go back to auto with each 'drive reset'.
