05-02-2019, 11:02 PM | #2 |
10744
Rep 3,690
M Brakes require 18" minimum, I think.
Blubaron791434.50 |
05-03-2019, 04:32 AM | #3 |
1863
Rep 5,140
17" OEM F30 wheels fit over grey standard brakes!
05-03-2019, 04:51 AM | #4 |
1890
Rep 3,877
With grey standard brakes - yes.
Question is why.... looks horrible. And that on a 40i...
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
tex26702412.50 |
05-03-2019, 06:21 AM | #6 |
279
Rep 268
For winter tire setups it is the recommended size with 225/50-17 square tires. It is usually used for winter or bad road areas but with good quality tires it will work fine and be comfortable.
05-03-2019, 07:29 AM | #7 |
8245
Rep 16,088
+1. The more rubber and less metal between the car and the road the less the likelihood of pothole damage to both tires and rims. Larger rims with shorter sidewall tires look nice, but they're not practical. Looks sell, practicality doesn't.
05-03-2019, 07:29 AM | #8 |
1890
Rep 3,877
Recommended by whom? 👀
The smaller the rims, the more comfortable the ride. But 17" are just too small (aesthetically) for F3x. And the soft ride contradicts a sporty engine. I drive on 18s in the winter. Wouldn't go lower. Comfort is good. I am sure it can be even better with non-RFT tires
05-03-2019, 07:39 AM | #9 |
8245
Rep 16,088
I can pretty much tell the age of the posters by the responses. The first car I had that came with 17s was my 2003 Toyota Matrix XRS. It came with summers, and I was stuck using them for the first winter, because at that time there were no 17 inch winters or even all seasons other than truck tires. That's 17s, gentlemen. 18s were still over the horizon.
05-03-2019, 09:12 AM | #10 |
1890
Rep 3,877
I doubt you can, but you can certainly tell how much people (of different ages) care about their vehicles.
P.s. My Audi has 17" for the winter and that's perfectly fine. Different car, different looks. And my colleague's 650i looks a bit silly even on 19". Bottom-line: don't compare with a 20 year old Mazda please. P.s. sorry - Toyota.
Machinebuilder278.50 tex26702412.50 |
05-03-2019, 11:40 AM | #11 |
1890
Rep 3,877
I stumbled upon some photos of a 3-series with 16". Even more comfortable... I guess 🙄
Swappy531.50 |
05-03-2019, 01:16 PM | #13 |
279
Rep 268
Skyhigh........check out Tirerack.com's package 17" Package
Tires: Michelin Alpin A4 ZP Wheels: Sport Edition F12 or equiv. BMWNA recommends the same. I totally understand you can also run 18" inch if you prefer but he asked if he could use 17" and yes he can. |
Swappy531.50 |
05-03-2019, 05:05 PM | #14 | |
Rep 22
Love the replies, thanks!
And FWIW, here's another benefit to running smaller wheels in the winter. When you're out drifting and doing donuts in unplowed parking lots the reduced clearance with the brakes means less snow gets packed onto the inside surface of the wheel. I know from experience. Quick tip from a former Subaru driver there... |
05-04-2019, 04:29 AM | #15 |
1890
Rep 3,877
Go 16" then. You'd be the star of the drift, guaranteed. And no snow on the inside.
05-04-2019, 06:06 AM | #16 |
68
Rep 117
Went for 205/60 16 for winter setup. Don't care much about the looks as the car always looks ugly in winter being covered with salt and dirt. Care even less about crappy roads, potholes, prices on new tires etc. Ride smoothness and road noise are much better than on summer 18s, handling is naturally much worse, but I don't need it much on the roads covered with slush and ice.
Narrow tires also provide better grip and traction in snow and on ice. |
Machinebuilder278.50 |
05-04-2019, 12:45 PM | #17 |
1890
Rep 3,877
Common misunderstanding. Not true. Narrow tires provide better grip in snow (and mainly fresh snow) only. On ice it is the surface area that matters, hence wider tires, better grip.
05-05-2019, 06:11 PM | #19 |
1890
Rep 3,877
If you don't get traction with wide tires, you certainly ain't getting any with narrow ones. Not on hard ice (e.g. ice-covered asphalt)
Try riding a bicycle on ice and see how much traction you get. Or are your ice skates wide?
quikM2371.00 |
05-06-2019, 08:39 PM | #20 | |
Rep 22
For accelerating and braking on any snowy surface (fresh or compacted), I still think the narrower tire has the advantage. (Within reason obviously - you wouldnt want bicycle tires...) |
05-06-2019, 08:45 PM | #21 |
Rep 22
Are you sure 16's will fit over the 340's brakes? Im pretty sure even my A4 needs at least 17's. <shrug>
05-07-2019, 12:45 AM | #22 |
1863
Rep 5,140
