BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Went Autocrossing and have questions
      08-03-2008, 07:57 PM   #1
BeAmW335i
27
Drives: 2007 BMW 335i
Smile Went Autocrossing and have questions
I went Autocrossing with the local Corvette club in my stock 335i coupe. My tires were set to 38psi cold all around. After the first few laps (yes, we had 10 laps), I noticed that my car started sliding around coming out of the turns, and I was also fighting the car during the turns (front tires look worst than the rears). After all the laps were over, one member suggested that I lower the tire pressure after the first few laps, because it was probably in the lower 40s. I didn't actually have a guage with me to check it.
I'm going back in 2 weeks, and would like to find out what was causing this problem. Maybe I was going too fast into the turn...I dunno.
Thank you.
2007 335i Coupe
Black Sapphire Metallic | Coral Red | Gray Poplar Wood Trim | Sports Package | Premium Package
      08-03-2008, 08:04 PM   #2
longodj
longodj's Avatar
75
Drives: 135i
2007 335xi  [0.00]
1974 VW Beetle  [0.00]
Thank you.
Keep the fronts ~2-3psi higher than rear. Get a gauge for sure, $7 at Pepboys :-P
      08-03-2008, 10:49 PM   #3
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
Yes, I agree the tire pressure could be too high. I'd start off with 32psi cold. Most people increase the tire pressure to try and prevent sidewall roll over, and if you have run flat tires, r compound tires, or a street tire with mega stiff sidewall (RE01R, RT615, etc) you don't need high air pressures. (Also, in all tires, high pressure decreases available grip because the contact patch is decreased.)
Also, you could be trying to go too fast in the slow sections. You should ask an experienced person to ride with you and give you pointers.
Best of luck!
